Old 06-19-2003, 08:49 PM   #1
SSR
Member#: 14760
2002 Legacy GT LTD
Black Granite Pearl
Question Weird Noises When Braking
This sound doesn't happen during normal speeds, only during high speeds, around 80kph+ and sometimes going downhill when speed picks up and I brake.
Its really hard to describe what it sounds like. It kinda sounds like a knocking noise or kinda like a flapping noise.
I checked all around the car, everything is fine.
SSR is offline   Reply With Quote
Old 06-20-2003, 08:16 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
check to make sure the caliper bolts and everything are secure.
Legacy777 is offline   Reply With Quote
Old 06-20-2003, 11:07 AM   #3
Oquipah
Member#: 9689
1998 Legacy GT
Question
Yeah, I get an audible click sporadically when applying brakes too, although it's at any speed.
The caliper was my first thought, since the dealer had to replace one recently.
Guess I should set up an appt.
Peace,
Oquipah
Oquipah is offline   Reply With Quote
Old 06-20-2003, 01:48 PM   #4
Legacy777
Member#: 4800
I had one of the bolts come loose and back all the way out that hold the caliper to the guide pins. It's pretty f'd up if you ask me. That could cause some serious issues.
Luckily it didn't cause any major damage, just tore off the wheel weights and scuffed up the wheel.
Other thing I just thought of is the pad itself. I had an issue several years back where I got the pad misaligned and when I put everything back together it separated the pad from the backing. What I got was this *ding/ting* sound every time I applied the brake. What had happen was the back got bent back so it was not keeping things tight any more and the pad was moving back and forth.
You may have something similar to that. The pad may not be damaged, but it still may be moving around.
Old 06-20-2003, 05:41 PM   #5
SSR
Member#: 14760
2002 Legacy GT LTD
Black Granite Pearl
If I bring to the dealer to have it looked at and repaired, is it under warrenty?
Old 06-20-2003, 06:58 PM   #6
Legacy777
Member#: 4800
It depends what the problem is.
If they are the only one who has touched the car, and there is a part missing, or if something not right, then yeah I would say they will have to eat the costs. If it's a caliper like before, then yeah I'd say it should be covered.
About the only thing I w0uldn't think would be covered would be a wear item, lets say you need new pads, that wouldn't be covered. But without taking it in there and seeing, or looking yourself, it's hard to say.
Josh
Weird noise when i brake.... JustAnotherSubie Newbies & FAQs 11 07-19-2009 01:58 AM
Weird noises when turning, popping noise HELP! idrum2loud Brakes, Steering & Suspension 13 07-07-2008 12:42 AM
24k miles on car and all of a sudden weird grinding noise when braking cold. Eric SS Brakes, Steering & Suspension 5 04-14-2003 07:00 PM
weird noise when down shifting from 3rd to 2nd Ghostrider Vancouver Impreza Club Forum -- VIC 7 03-31-2001 04:55 PM
