Old 06-20-2003, 10:00 AM   #1
markraz
Member#: 27237
2000 RS
Default 2004 Forester 2.5XT turbo?
The new 2004 Forester XT is a turbo with 210 hp. I am assuming it’s the same 2.5 engine thats in my 00 rs. If so wouldn’t that make a pretty reliable (designed specifically for the 2.5 engine by subaru) 210 hp RS?
markraz is offline   Reply With Quote
Old 06-20-2003, 11:01 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
yes it would, assuming everything basically bolts up with no issues, it would be like doing an EJ20T engine swap from a wrx, except now its from the forester with the 2.5l engine.
this might be expensive depending on how quickly you are planning on doing it. it might be even cheaper to just do an aftermarket kit, because i believe that a stage 1 kit at like 4.5psi, would easily be 210 at the crank. and if you combined that with engine management you could have a reliable yet fun RS.
hey guys, 210 sounds like a fairly low output considering that its turbo'd, i know they prob redesigned the engine to handle the boost but it doesnt sound like they did much because our stock EJ25 can easily take 210. what do you guys think? sorry if this info already came out i havent researched the forester much.
Ben
Old 06-20-2003, 11:20 AM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
The forrester and baja motors are still kind of a mystery. Personally I assume the blocks are the same as the STi: Semi-closed, reinforced. I'm guessing 8.5:1 CR, but I do not know what the pistons/rods are made of. The turbo on the non-STi 2.5s is small, but I do not know which turbo it is. Also, the intercooler is TINY compared to a WRX I/C. Also, remember, the non-STi 2.5s are tuned for torque, not hp. They are stump pullers, not ground pounders. ECU tweaks alone should be able to get more WRX/STi-like powerbands, that and upgrading the I/C turbo should make for a rather fun ride. The block should drop right in the our RSs, not sure how well it'll run w/o the ECU though.
Old 06-20-2003, 12:42 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
what kind of heads are thies things useing...?
Old 06-20-2003, 02:25 PM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Good question.
2004 Forester 2.5XT - TIRES bunnyfast Forester Forum 38 02-22-2005 08:21 AM
Blow off valve for 2004 Forester 2.5XT SirWilliam Newbies & FAQs 10 06-25-2004 05:59 PM
2004 Forester 2.5XT = [email protected] 1/4 mile daytontp General Community 75 11-25-2003 06:33 PM
2004 Forester 2.5XT its coming WestCoastPimp News & Rumors 6 02-22-2003 01:01 AM
2004 Forester 2.5XT lakepop Forester Forum 74 02-18-2003 09:59 AM
