Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 12-14-2000, 12:39 AM   #1
glenstiles
Member#: 2827
2002 WRX wagon
Silver, baby, silver
Post TPS adjustment for 2-3 shift
Hi.
Just reporting that I am trying out this mod right now. I adjusted the TPS clockwise in an effort to cure the slight rise in revs in the 2-3 part throttle shift. I found this info from the SVX CD-ROM yahoo database. Supposed to take a few days to see if it works, so far so good- no check engine light, seems to shift with a little less hesitation, but will report back with any info/findings. BTW- I do have the stock resistor connected while doing the TPS mod.
Glen
glenstiles is offline
Old 12-14-2000, 08:54 AM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
Did you reset the ECU after doing it?
kastle is offline
Old 12-14-2000, 10:00 PM   #3
glenstiles
Member#: 2827
2002 WRX wagon
Post
Nope, didn't reset the ecu. The car seems like it is learning, as the 2-3 slight rise in revs/hesitation is gone, and the car drives like it holds the gears longer (?) Any way, that is the sensation I'm getting. I'll have to see if this works out...
glen
Old 12-16-2000, 11:52 AM   #4
CRZ_MSL
Member#: 1610
Question
How do you adjust the TPS?
CRZ_MSL is offline
Old 12-16-2000, 07:24 PM   #5
glenstiles
Member#: 2827
2002 WRX wagon
Post
The TPS is under the H-6 cover- take off the cover, just two plastic screws hold it in place. The TPS is mounted on the driver side of the inlet going to the manifold, with a few wires sticking out the bottom. Two screws hold it in place- just loosen the screws and turn the sucker clockwise- I marked the position beforehand by placing a small notch so I could return it to the stock setting easily.
Glen
Old 12-19-2000, 11:04 PM   #6
glenstiles
Member#: 2827
2002 WRX wagon
Smile
Update- after doing the TPS mod for a little while now, I can say that it really helps the shift quality. Less harsh than the resistor mod, and just the right amount of shift smoothness. Nice comprimise. I wonder if my TPS settings were off previously or something? The car feels 'right', its hard to explain, but the shifts don't seem as vague now, and no surge on the 2-3 shift. Never had a problem on the freeway, but around town, it was annoying. No more...but...my mileage dropped a lot. Now I am going to assume its the computer relearning things, but I may have to adjust things slightly towards the original setting if the mileage continues to be this low...
to be continued...
Glen
Old 01-10-2001, 10:55 PM   #7
glenstiles
Member#: 2827
2002 WRX wagon
Post
TPS Update- the mileage was getting too low. I lost a few miles a gallon in the city- not only does that cost more at the pump, but that extra fuel has got to be going somewhere, and if its out the tailpipe, it'll eventually ruin the cat. Back to the stock settings (or closer to it.)
Glen
Old 01-11-2001, 08:50 AM   #8
CRZ_MSL
Member#: 1610
Smile
Hmmm...
[This message has been edited by CRZ_MSL (edited January 11, 2001).]
CRZ_MSL is offline
Old 01-11-2001, 08:50 AM   #9
CRZ_MSL
Member#: 1610
Smile
Thanks for the update.
CRZ_MSL is offline
HTML code is On
TPS Adjustment for 93 Imp 3rdeyeinfected Service & Maintenance 1 12-25-2008 04:32 PM
Help! My shifter buzzes/vibrates on the 1-2 and 2-3 shifts Butt Dyno Transmission (AT/MT) & Driveline 9 05-06-2004 01:46 AM
4-EAT: slow 2-3 shift MaddMax Transmission (AT/MT) & Driveline 5 01-16-2004 12:12 PM
Small whine in 1-2 and 2-3 shift when cold jmaiken Transmission (AT/MT) & Driveline 3 10-28-2003 03:37 PM
keep missing my 2-3 shift, finding 5th instead of 3rd annointed Transmission (AT/MT) & Driveline 16 05-13-2002 01:07 AM
