Old 06-20-2003, 07:51 PM   #1
BlackEye
Member#: 36203
2003 WRX
Platinum Silver Met.
Default Installing Koni Inserts...
Has anybody here installed their own Koni inserts? Aparently you have to cut off the top of the strut housing and pull out the factory insert on the SOA struts, then press in the new insert.
This all sounds kinda hairy, have any of you tried it?
Or, do any of you know of any instruction sites for it. I was going to buy the inserts off Tirerack but I wanted to check with all of you first.
Russ
BlackEye is offline   Reply With Quote
Old 06-20-2003, 11:23 PM   #2
teiva-boy
Member#: 22825
teiva-boy is offline   Reply With Quote
Old 06-21-2003, 11:06 AM   #3
OddMonkey
Member#: 24953
02 wrx
dirt flavored silver
I did mine, and it wasn't nearly as bad as i thought.
Some notes:
Make sure to measure your cut off points carefully; if you cut too far down the strut body you get a nice door stop instead of a strut.
You have to drill a large hole in the bottom of the tube. It says 14mm in the instructions, but I looked everywhere for a 14mm bit and wound up using a 9/16 and it worked just fine.
I also could not find a 1/2 drive 7mm allen wrench to torque the inserts to the tube, so I used some loctite and tightened them to the "very firm" level
The torque specs on the three top bolts is like 14.5 ft/lbs, so be carefull when you reinstall.
Get an enormous breaker bar and a couple/three 19mm sockets to get the front suspension parts off. No joke on on this one. I used the handle for my floor jack, and though I was gonna get the car off the jackstands before it popped free.
I picked up a GearRatchet from Sears, and that made removing the top hats from the old struts really easy. It also came in usefull for a front sway bar install.
Thats all I can think of for now, let me know if you have any other questions. It *is* worth the effort
OddMonkey is offline   Reply With Quote
Old 06-21-2003, 11:13 AM   #4
BlackEye
Member#: 36203
2003 WRX
Default THANKS!!!!!!!!
Awsome link, thanks...
Russ
Old 06-21-2003, 12:01 PM   #5
teiva-boy
Member#: 22825
If you need any special tools, Harbor Freight has em.
I got my 7mm allen wrench set(3/8th") Works great on my torque wrench
You dont need to have a 14mm drill bit. You can use a smaller one and ream(sp?) the crap out of it to get to the desired size. I did this.
As for cutting of the top, you dont have to measure anything. You can cut it 1" too much and it'll still work. It gets bolted down from the bottom, so the top side cut is irrelavent. Just cut it as close to the top weld as possible.
Old 06-21-2003, 01:40 PM   #6
OddMonkey
Member#: 24953
02 wrx
On mine the inserts fit kinda loose, up to the point where there were raised ridges that held it in place as I tightened the allen bolt, YMMV.
Yep. I think even with measuring thats the way mine turned out. It was the first "real" work I had done to the car, so I was paranoid about screwing it up
Old 06-21-2003, 01:55 PM   #7
Chuck H
Member#: 20442
I'm still in the planning stages of my suspension upgrades. Previously I had all but made up my mind to go with the dealer SPT spring/strut package. But these Koni inserts sound like an attractive cheaper alternative.
The only experience I have with Konis is that they are factory equipped on my ACR Neon, and they make a HUGE difference in the handling of that car. Can anyone compare the WRX Koni inserts to the SPT suspension setup as far as handling? Also, what springs is everyone using with them? I tried Eibach Prokits on my Neon and wasn't impressed. I'd prefer a linear rate spring to a progressive one if there are any good options available.
Thanks in advance for any insight.
Chuck H is online now   Reply With Quote
Old 06-22-2003, 09:17 AM   #8
sdecker
Member#: 14717
2002 WRX, WR Blue
Complete n00b Racing
Blackeye:
PM Steve_D if need further install help. He did mine for me and claimed it was very simple.
Chuck H:
Consider using the Prodrive springs -- they are linear and roughly 10-15 percent stiffer than stock. When combined with the Konis I dropped 3 seconds a lap at Road Atlanta. That's *huge*, but you probably already know that.
I can't compare to the SPT stuff, but the Prodrive/Koni combo works great. Go here for more info: http://forums.nasioc.com/forums/show...=koni+prodrive
GTguy (Kevin) can probably give you more feedback on the SPT stuff as well.
Good luck,
Scott
sdecker is offline   Reply With Quote
Old 06-26-2003, 09:44 PM   #9
Gonz
Member#: 18642
2005 Impreza WRX STi
I'm installing the Koni shock cartrdiges on Sunday. The only real concern I have is about where to cut.
I saw the post about " cut as close to the top weld as possible"
I haven't looked at the strut carefully (without the dust cover) since helping someone put springs on a while back...
The strut has a gold cap on the top. I think, but am not sure if this cap can be popped off. The reason I think that is can be is because the instruction for my ground control spring sleeves say " NOTE: knock off gold cap to install coil-over hardware, then re-install gold cap"
So the question is are you guys cutting just below the Gold cap, or removing the gold cap and cutting just below the top end of the strut housing ??
G
Gonz is offline   Reply With Quote
Old 06-26-2003, 10:53 PM   #10
OddMonkey
Member#: 24953
02 wrx
below the gold caps... here is where I cut mine:
you can probably cut them closer to the tops than I did, but that worked perfect for me.
now I'm trying to figure out why I still have the things :/
Local Shop that sales & installs Koni inserts? obraystyle Rocky Mountains Impreza Club Forum -- RMIC 12 06-17-2009 02:03 PM
02/03 Koni inserts vs. 04/05 Koni inserts Ski Bum Brakes, Steering & Suspension 13 11-07-2005 10:11 AM
Who installs Koni inserts? Rich10 Tri-State Area Forum 7 06-21-2005 04:11 PM
How is it to install koni inserts? titanium wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-08-2004 04:45 PM
Anyone here actually install Koni inserts? bbaerotek Brakes, Steering & Suspension 15 02-27-2002 01:20 PM
