Old 06-21-2003, 08:22 PM   #1
Mancini
Member#: 20726
Thumbs down Vortech FMU
After having erratic fuel pressure for the past week I decided to ditch the FMU and go with just the SAFC2. All I can say is wow, what a difference. Power delivery feels much smoother and my EGT's are finally where they should be.
The FMU was screwing up pressure all over the place. Idle was too high, around 38psi. The FMU was supposed to be 6:1 and I was only seeing a max fuel pressure of 52psi. It would then fluxuate and I'd get a max of 48psi sometimes. I decided to pull the thign and I'm now idling around 34 with a max on boost of 48. Power is just more consistent.
Anyways, just thought I'd share my experience with the FMU. And it was hooked up correctly...dunno why it wasn't working correctly.
Mancini is offline   Reply With Quote
Old 06-22-2003, 04:19 AM   #2
Unsung Boxer
Member#: 37196
Good call, i never understood the need for an FMU... always seemed like a bandaid on a broken arm... glad the SAFC is workign out. I am going w/ that route too.
let us know ur results.
Unsung Boxer is offline   Reply With Quote
Old 06-22-2003, 10:50 AM   #3
Daveish
Member#: 8935
2001 Impreza 2.5RS
Mancini -- glad to hear that. I had the same problem with my vortech -- although I never measured what it was doing with the fuel pressure, the second I took it out, my car ran exactly like I wanted it to all these years... (well, after twiddling with the safc some)
Daveish is offline   Reply With Quote
Old 06-22-2003, 08:12 PM   #4
Avenger
Member#: 1234
I'm just using a regular adjustable fuel pressure regulator and it seems fine.
Avenger is offline   Reply With Quote
Old 06-23-2003, 04:49 AM   #5
Shinji N
Member#: 3987
1999 Miata
ANALOGY TIME!!!!
Mancini:maf::avenger:map
Shinji N is offline   Reply With Quote
Old 06-23-2003, 11:05 AM   #6
Avenger
Member#: 1234
Originally posted by Shinji N
ANALOGY TIME!!!!
Minor details.
I always thought the MAF ecu were better at fuel than the map ecu, with less problems.
Old 06-23-2003, 11:18 AM   #7
Mancini
Member#: 20726
I've noticed that most factory turbo'd cars run MAF or Karman instead of MAP. But most aftermarket ECU's use or prefer the use of MAP. Kinda strange, oh well...
A buddy of mine is converting his DSM, which uses Karman, to a GM MAF. The coolest part, he's going to run blow through so he can still vent this BOV to atmosphere but has the accuracy of a MAF sensor. I may consider this if I ever get a front mount
BTW, I took the FMU apart, it looks cheap and crappy. No wonder it wasn't very accurate. Live and learn I guess. Also I recommend the SAFC2 if you can get your hands on it. The 12 points of adjustment makes things fairly easy to correct in specific areas.
Vortech FMU Calibration Suggestions SCOOBER Engine Management & Tuning 0 05-14-2003 06:08 PM
Vortech FMU Question... SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 0 05-05-2003 03:03 PM
Do I need to put the Vortech FMU at the end of the vacuum line? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-20-2001 04:33 PM
Will this MSD adjustable FPR work along with the Vortech FMU? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-15-2001 11:48 AM
Puzzled by Vortech FMU Full Recal Kit the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 16 10-15-2001 03:15 AM
