Welcome to the North American Subaru Impreza Owners Club Saturday July 12, 2014
Old 06-22-2003, 12:52 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default UTEC valet mode: safe to drive in?
I know this sounds like a stupid question but are there any bad consequences of running in the valet mode for a prolonged period of time. Just for fun i drove around town in this mode and it felt like driving my old RS! Ahhhh the memories.
Ed
edkwon is offline   Reply With Quote
Old 06-22-2003, 03:24 AM   #2
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Some valet modes significantly retard the timing, which may raise EGTs too much.
If you have an EGT gauge you can verify this. With the low boost it probably is not a concern.
Concillian is offline   Reply With Quote
Old 06-22-2003, 06:27 AM   #3
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Interesting, even with the peak boost capped off at 7-8 psi?
Ed
Old 06-22-2003, 12:58 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I don't know, I'm just saying that would be the only thing I would be worried about. I also said:
"With the low boost it probably is not a concern."
Old 06-22-2003, 01:01 PM   #5
Bolster
Member#: 22290
2002 WRB WRX Wagon
You might also fowl your sparkplugs running in valet mode for extended periods of time. And you might damage your cats if you did for a long enough time.
Bolster is offline   Reply With Quote
Old 06-23-2003, 11:49 AM   #6
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Why does valet mode change the fuel/air mixture?
WRX03 is offline   Reply With Quote
Old 06-23-2003, 11:58 AM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
No, it uses the Fuel map that is in map #1
Old 06-23-2003, 12:10 PM   #8
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Yeah and my map #1 is the stage one which would be over-rich fuel map for the delayed timing of the valet mode.
I guess i would have to put low low-octane timing map in slot #1 in order to make valet mode actually driveable.
Ed
Chunk in Sidewall: Is this still safe to drive on? scottjua Tire & Wheel 5 08-10-2007 10:04 PM
Safe to drive in snow on stock tires... golovko Tire & Wheel 33 12-11-2006 07:23 PM
is it safe to drive hard with a silencer in your muffler? blackie Factory 2.0L Turbo Powertrain 13 02-18-2004 10:22 PM
