Old 06-22-2003, 02:32 PM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Default RRFPR install???
I have to install a RRFPR but i dont have the instruction. It look simple but i dont know if it go after the fiel fiter on the main line or in the return line after the fuel rails???
Please need help?!?!?!
JST is offline   Reply With Quote
Old 06-22-2003, 02:41 PM   #2
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
The RRFPR is installed by tapping into the fuel return line. That line is located on the driver side of the engine compartment. The return line is connected to the MIDDLE line on the intake manifold and the large gray line coming out of the firewall. Loosen the factory hose clamp that holds the fuel line to the metal line on the intake manifold. Connect a hose to the metal line that you just removed the factory hose from. It is VERY IMPORTANT to make sure that the correct hose goes into the correct port of the RRFPR. The new fuel line that goes FROM the intake manifold goes to the SIDE port of the RRFPR. Connect the facotry fuel line to the other port that comes out of the CENTER of the RRFPR. Tighten all the hose clamps.
Wedge is offline   Reply With Quote
Old 07-01-2003, 12:13 PM   #3
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
thanks Wedge for the info!!!
I need help installing an rrfpr and fp (LI) gto7419 Tri-State Area Forum 2 12-25-2006 05:43 PM
do i install the fuel pressure gauge after the rrfpr? GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-08-2004 05:47 PM
RRFPR Install Graham Normally Aspirated with bolt-on Forced Induction Powertrain 8 03-04-2002 06:13 PM
RRFPR install Pipercub Normally Aspirated Powertrain 14 01-28-2001 08:29 PM
Installed the Bell RRFPR..what a diff! mjos Technical Forum Archive 12 05-15-2000 12:20 AM
