Old 06-22-2003, 11:57 PM   #1
my03nywrx
Member#: 37791
03 WRX sedan
Thumbs up Prodrive Stage 2 kit
Finally had time to install my kit(muffler/midpipe/ypipe/ECU reflash). I went with a second ECU to eliminate down time. Huge improvement low-mid & high end. First, max boost is up almost 3 psi. 1st gear has full boost and there is no need to downshift from fifth when passing. It pulls like a up hill. Even top end seems endless at 100 mph. There are no check engine lights . I am extremely happy with the results. I did order the '02 ECU for my '03 sedan because Prodrive is currently patching the reflash software for the '03s. Eventually I will go with the Stage 3(stage2+downpipe/uppipe/reflash). Just wanted to thank Mike @ Subaruxtras.com for his help and putting up with all my phone calls .
my03nywrx is offline   Reply With Quote
Old 06-24-2003, 12:21 AM   #2
downeyer
Member Sales Rating: (9)
Member#: 10784
Platinum Silver Metallic
Awesome...thanks for the writeup. I'm planning to purchase the Stage 2 once the dyno charts are posted and everything looks good. I can't believe they pushed the max boost up 3 psi. Sounds a little high to me considering the output is only an additional 40hp.
downeyer is offline   Reply With Quote
Old 06-24-2003, 02:30 AM   #3
my03nywrx
Member#: 37791
03 WRX sedan
Default max boost
I was at .09 on stock boost gauge(which I read was 13 psi) now max boost is at .11-.12.(.1 is 14.5 psi). Now I'm guessing unless someone has the conversion, max boost gain is about 3 psi. I wish there was a awd dyno near me, but for now I will have to wait for the posted results from Prodrive.
Old 06-24-2003, 02:45 AM   #4
my03nywrx
Member#: 37791
03 WRX sedan
Smile PPP stage kits
All kits are listed in wheel HP. Actually the additional 40whp for the stage 2 kit brings you to about 280 at the crank. Stage 3 is about 309 hp@ crank(228whp).
Old 06-24-2003, 07:30 AM   #5
jaysp55
Member Sales Rating: (1)
Member#: 34151
2011 outback sport
Sound's good! I also purchased the same kit thought Mike @ Subaruxtras and I am patiently wating for my 03 manual patched ECU.
So the gains are immediatly noticable yeah? With the Cobb reflash some people say it seems to get faster and faster, have you noticed the same with the ppp st2?
Thanks,
J
jaysp55 is offline   Reply With Quote
Old 06-24-2003, 03:48 PM   #6
03WRXMA
Member Sales Rating: (7)
Member#: 35081
2012 WRX
Default Re: Prodrive Stage 2 kit
Sell me your ECU, so I can get my reflashed, then I will sell you back mine
03WRXMA is offline   Reply With Quote
Old 06-24-2003, 05:28 PM   #7
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
Stage 2, what is the horse power. What is the PSI? is it well worth it?
Chris
DoDO Brown is offline   Reply With Quote
Old 06-24-2003, 06:22 PM   #8
S-Rex
Member#: 19204
WR Blue
Default maximum boost and egt attained?
What is the max boost attained with the stage 2?
What is the max attained for egt?
Thx,
S-Rex is offline   Reply With Quote
Old 06-26-2003, 08:34 AM   #9
subaruxtra.com
Vendor
Vendor Sales Rating: (1)
Member#: 31807
Dyno plot for the PPP kits this was done with 91 octane and if you have 93 octane your results will be higher.
subaruxtra.com is offline   Reply With Quote
Old 06-26-2003, 09:27 AM   #10
CirrusWRX
Member Sales Rating: (4)
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
How was the install? Specifically for the muffler and midpipe? (I have the IC hoses already, and I know how 'easy' it is to swap ECUs. Just curious on approximately how much time I should set aside for the install. Also, any instructions with this stuff, or any additional literature of any kind from Prodrive?
CirrusWRX is offline   Reply With Quote
Old 06-26-2003, 03:37 PM   #11
O2-GGA
Member Sales Rating: (12)
Member#: 23222
02 Prodrive wagon
I was also wondering if the WRsport exhaust will fix with the mid pipe.....
Steve
O2-GGA is offline   Reply With Quote
Old 06-26-2003, 10:17 PM   #12
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
From what i have gather, this is what it might look like? Anybody can jump in. I might be off a little bit.
Stock: 227 hp @ 6000 rpm
217 ft lb of torque @ 5200 rpm
Stage 2: 260 hp @ 6000 rpm
260 ft lb of torque @ 3300 rpm
Stage 3: 284 hp @ 6000 rpm
275 ft lb of torque @ 5100 rpm
Chris
Old 06-26-2003, 10:22 PM   #13
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
What is the PSI set at?
Old 06-27-2003, 12:05 AM   #14
my03nywrx
Member#: 37791
03 WRX sedan
Lightbulb Prodrive stage 2 install
Sorry I didn't comment on the install. Once up on jack stands the muffler takes about 20min(changed rear diff to synthetic at this time), midpipe 30min(o2 sensor was a pita to remove had to use my impact gun), ypipe 25min(also decided to change tranny fluid to synthetic and install stop pitch while IC was off). Just wanted to add a note; if you didn't purchase the kit from Subaruxtras.com you will need a 2" bolt to connect midpipe to downpipe and gaskets are not included(Mike from Subaruxtras.com sends them out with the kits). I'm looking into buying the PSI3 ecu monitoring computer which states it will display boost in psi/ Air-fuel/volts/speed/coolant temp/egt temp/ C.e.l.'s etc... I would love to compare these results for when I go to the stage 3.
Anthony
Old 06-27-2003, 01:42 AM   #15
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
Can you post pictures of what it looks like on your car? Please Please?
Chris
Old 06-27-2003, 07:43 AM   #16
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Thanks for the email MY03-- just a quick couple of questions:
1. What bolt is required? (is it because the stock bolt is too big/small, or too long/short??)
2. So I take it you did NOT reuse the old gaskets? Anybody see any problems in doing so? (I know- exhaust leaks...) but you know what I mean...
and yeah, if you could take some pics, that'd be cool! thanks for all your help thus far!
Kyle
Old 06-28-2003, 02:06 PM   #17
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
with all the kits and stages out there, would this one the best value for your money?
chris
Old 06-30-2003, 01:22 PM   #18
subaruxtra.com
Vendor
Member#: 31807
my03nywrx: Here are your pics
Old 06-30-2003, 01:23 PM   #19
subaruxtra.com
Vendor
Member#: 31807
here is his other pic
Old 07-01-2003, 04:09 PM   #20
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
I will try and have mine installed this weekend, and I will take sound clips. Thanks for the pics!
Old 07-02-2003, 09:16 AM   #21
my03nywrx
Member#: 37791
03 WRX sedan
Cool PPP stage 2
Just wanted to share a little info. About 500 miles and loving every minute of it. Gas mpg is 21 more city than highway driving; with a heavy foot
Old 07-03-2003, 12:57 PM   #22
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
How big is the coffe can tip? Is the sound different than just the Stock Prodrive Axle back?
Chris
Old 07-03-2003, 10:46 PM   #23
jaysp55
Member#: 34151
2011 outback sport
Here is my review on the ppp st2 kit.
http://clubwrx.net/forums/showthread...threadid=29543
J
Old 07-04-2003, 11:22 AM   #24
DoDO Brown
Member#: 35942
94 Turbo Legacy SW
Yes the pictures look very nice. So you send them your stock ecu, they give you a different one? From what i have read, there having problems with the MY2003? Am ordering mine next week. We will see ut it goes.
chris
Old 07-04-2003, 11:49 PM   #25
my03nywrx
Member#: 37791
03 WRX sedan
Default ecu
You get your same ecu back that you send them unless you buy a second one like I did. I believe they patched the reflash issue they had with the later model '03 ecu's.
FS: OH: Prodrive stage 3 kit, includes ECU silverwrxmike Engine/Power/Exhaust 52 08-26-2006 04:29 PM
CA: Gauging interest in Prodrive Stage III kit Dingo Private 'For Sale' Classifieds 19 01-11-2006 09:45 PM
cobb stage 2 vs. prodrive stage 2 oxtox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2005 08:59 AM
prodrive stage 3 kit South Coast Subaru Vendor 'For Sale' Classifieds 2 12-31-2003 02:00 PM
Prodrive Stage 2 kit my03nywrx Car Part Reviews 0 06-22-2003 11:25 PM
