Old 06-23-2003, 12:29 AM   #1
subywrxwrblu
Member#: 9332
Default Idling rough, can someone help me?
Hi,
My car over the past 3 months or so has been plauged with problems. Here is my latest problem, and hopefully the last.
To start off I will tell you my mods: axleback, up-pipe, EBC - set at 13.5lbs.
When my electric fans kick on my car starts to idle rough, according to my boost gauge it goes from 18 vaccum to 10, and flutters back and forth between the two. The RPMs also drop like it is going to stall but it never does. Once the fans turn off my car idles normal
I have to double check but when I checked the battery on the volt meter it stayed at 12volts, even when I turned the AC on and the fans came on. I will check that again tommorow to make sure, but until than does anyone have any insite to what it may be? Thanks
Kirk
subywrxwrblu is offline   Reply With Quote
Old 06-23-2003, 12:44 AM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I think it's normal. If not, mine does the same thing when the a/c is on. Not when just the radiator fans are on though
MAD REX is offline   Reply With Quote
Old 06-23-2003, 12:46 AM   #3
subywrxwrblu
Member#: 9332
hmmm, nah I mean this is really rough, like a V-8 with a lumpy cam in it.
I do know whatcha mean when they come on you can notice it, but I know this is definetly not right. Thanks
Old 06-23-2003, 08:21 AM   #4
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
Check your vaccum lines.
Other than that, you can have someone with DeltaDash increase the idle rpm.
Si2WRX is offline   Reply With Quote
Old 06-23-2003, 08:57 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The rough idle and vacuum drop when the fans come on appears to be from an abnormal load on the electrical system.
With the engine running and no accessories operating the system voltage should read somewhere around 13-14V. If it is reading 12V under these conditions there is a problem, the alternator may not be charging or the battery may be weak.
With the engine off the battery should read at least 12.5V after it sits for a while, if it is much less the battery may be bad (unless there is an excessive current drain somewhere pulling it down).
Old 06-23-2003, 09:32 AM   #6
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
That's a very good point. I've spoken to many WRX owners who have replaced their battery.
Old 06-23-2003, 01:24 PM   #7
subywrxwrblu
Member#: 9332
Thanks alot for your help guys, it actually was the battery. Can anyone recommend a good replacement battery? I was thinking Optima, but I don't know what type is the correct kind.
Thanks again.
Kirk
Old 06-23-2003, 06:14 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I highly recommend the Optima. The best fit for the WRX is the Group 35, I have a 35 Red-Top and it's great. The only extra thing you will have to do is replace the cable to the starter because it will be too short, not a big deal. Search for threads with "Optima" and my username and you will find lots of info.
HELP DFW: Can someone help me install my Recaro seat RIGHT NOW ASAP!!?!?!? fatcircles TXIC Private Classifieds 3 01-13-2008 08:42 PM
I need help in Ocala ASAP, can someone help me? imprezu South East Region Forum 2 09-14-2006 10:53 PM
My car is idling roughly. Can someone look at this DeltaDash data? maugustine Engine Management & Tuning 2 10-07-2003 03:27 PM
My car is idling roughly. Can someone look at this DeltaDash data? maugustine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 10:33 PM
('93-'01) I need a new carpet for my car, can someone help me? The Wraith Impreza Forum 3 06-08-2001 12:52 AM
