Old 06-23-2003, 09:04 PM   #1
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Default New fuel pump getting noisy.
I have a walbro 255 that came with my ludespeed kit. I t has been just fine I could barely here it why the car was running. I could here it clearly turning the ignition on. Now it is loud as hell sounds like a chevy truck fuel pump! Is this ok? Should I replace it? Fuel preasure seems ok.
Thanks
Ralph
cpu77 is offline   Reply With Quote
Old 06-23-2003, 09:27 PM   #2
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Get used to the Hummmm....
Thats normal for the High Pressure High Volume Walboros...
Zee
Sunrise City Rider is offline   Reply With Quote
Old 06-23-2003, 11:20 PM   #3
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Exclamation
Get an MKIV Supra pump. Same output.....and sealthy too!
Wedge is offline   Reply With Quote
Old 06-23-2003, 11:37 PM   #4
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
I s the Supra pump the same flow? If it's different do I need to make any changes?
Old 06-24-2003, 03:36 PM   #5
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
That sound is normal and I usually get it when its hot outside. My fuel pressure has not been affected and the A/F are the same as before. Get used to it
WRC 555 is offline   Reply With Quote
Is my fuel pump getting weak or is it the Turbo? ClayMac Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-20-2008 03:59 PM
new injectors and new fuel pump ROC pit-bull Engine Management & Tuning 1 08-21-2004 12:20 AM
So I was almost ready to put my new fuel pump in when.... scootr Normally Aspirated with bolt-on Forced Induction Powertrain 11 11-12-2001 03:46 AM
New Fuel Pump + FMU = No Change (help) HRE | giulio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-24-2001 07:38 AM
New fuel pump Really_Soaked Normally Aspirated Powertrain 3 04-29-2001 12:25 AM
