Old 06-23-2003, 11:18 PM   #1
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Default Couple of questions about the stock oil pressure sender...
1. Does anything else besides the oil pressure light in the instrument cluster run off it?
2. Is there a buzzer that goes off when it comes on and the engine is running?
Basiclly, I want to run an oil pressure gauge, and get rid of the factory sender. Just need to know those two things.
Thanks.
Impreza Rider is offline   Reply With Quote
Old 06-24-2003, 12:41 AM   #2
kaos200
Member#: 2692
yank it out, nothing happens
kaos200 is offline   Reply With Quote
Old 06-24-2003, 09:18 AM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Thanks.
Old 06-24-2003, 02:16 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it is a close at low pressure. so disconnecting it will have no effect
Old 06-25-2003, 04:47 AM   #5
Cusco
Member#: 6220
99 ej25sett/TEC II
-:GaraGe ChimEra:-
I thought at low oil pressure the oil pressure lighgt came on ? thats what happened to me on my MY99 RS. the oil was low so the light came on.. or am I misatajen? I guess the light comes on for low oil level? and not presure? so then the oil pressure light or check engine light goes on for high oil presure??
John
Cusco is offline   Reply With Quote
Old 06-25-2003, 11:04 AM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
right...
the sensor will close (make a circuit) at low pressure.. but it is normaly open (no circuit) .. this is why it is such a piece of junk. if it failed it would never close and you would have NO idea that something was wrong
Old 06-26-2003, 07:43 PM   #7
jeff22
Member#: 7534
99 impreza rs-t
rally blue pearl
Take it off! I took mine out and screwed in a greddy w/60mm gauge works great, justs bolts right in to stock location.
jeff22 is offline   Reply With Quote
couple of questions about the utec jemar2169 Engine Management & Tuning 2 01-19-2007 07:28 PM
I got a couple of questions about the gay community WRXedUSA Off-Topic 228 06-27-2006 01:03 AM
Couple of questions about oil cooling system PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-11-2005 02:36 PM
A couple of questins about the stock speakers. Sfire25 Car Audio, Video & Security 12 02-07-2005 09:20 PM
A couple of questions about the up-pipe dannyboy7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-14-2001 05:05 PM
