Old 06-23-2003, 11:47 PM   #1
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Default Custom Uppipe and down pipes
Why doesn't someone make a full mandrel bent stainless up and down pipe that fits the IHI or the garret turbos. Then RS guys would be able to bolt on what ever they pleased? Kind of like the bolt on upgrades the rex has? I would buy them. A 3" smooth downpipe would be nice. Then we could put any turbo that we want on. Am I missing something? I realize you not bolt any on there maybe just popular ones. Anyone know what shiv's kits come with turbo specs?
cpu77 is offline   Reply With Quote
Old 06-24-2003, 03:01 AM   #2
Shinji N
Member#: 3987
1999 Miata
I thought subachad was doing something like this?
Shinji N is offline   Reply With Quote
Old 06-24-2003, 02:37 PM   #3
craiggy20
Member#: 26262
01 01 2.5 RS
check out http://www.uniquemotorsports.com thats subachad's web site...im pretty sure that it says that he will weld on a different flange to the up-pipe that you order.
craiggy20 is offline   Reply With Quote
Old 06-27-2003, 01:14 AM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Hi guys, thanks for the replies. I can't really just weld on another flange because the turbo itself might not fit. For me to make a set of pipes for another turbo other than the TD04L and bolt on replacements, I need to borrow the turbo.
There's also the fact that until I get into another place, I don't have the workspace to produce the parts.
That said, I will be making pipes next week and am currently taking orders. Pipes sold will be on a first come first serve basis. Please refer to the site mentioned above for more info or drop me an email.
Thanks,
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 06-27-2003, 12:46 PM   #5
craiggy20
Member#: 26262
01 01 2.5 RS
oops, sorry for the confusion...and thanks for correcting me
Old 06-27-2003, 02:43 PM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
big bump for Chad's flanges!! and a quick question: I've got an ancient VF10 from a Loyale and am using your "universal" IHI UP flange and your 4 bolt DO flange... what on earth do I have as bolt on options? TD05 from an early STi? Other? Anyone know?
Old 06-27-2003, 04:24 PM   #7
subachad
Member#: 8488
Teal
You can use any WRX upgrade turbo if you change the DP flange. Otherwise, I really don't know what upgraded turbo works with that 4bolt DP flange.
Chad
Old 06-27-2003, 04:41 PM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Chad
That's the kicker, w/ the 4 bolt flange I know there's got to be something out there that won't require me rewelding... its just a matter of finding what that something is.
Old 06-28-2003, 12:44 PM   #9
subyrs555
Member#: 26572
2000 Impreza 2.5RS
Blue Ridge Pearl
subachad- i have a set of the uniquemotorsports up/down pipes.....im sure ill loose my cruise control but it appears that I may lose my a/c......sorry if this sounds ignorant but i have yet to test fit the pipes with the turbo..thanks Landon
subyrs555 is offline   Reply With Quote
Old 06-28-2003, 05:48 PM   #10
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
subyrs555 - You won't lose your cruise control if you just relocate it somewhere else in the engine bay. Relatively easy. You also certainly won't lose your A/C. It'll make more sense once you bolt it all up.
BOY - A turbo from an early 90s Legacy Turbo should be a bit larger IIRC. It uses the same bolt pattern. VF11 or 12 or something to that effect.
cpu77 - I'm working on designing some up/downpipes that I would like to produce. A garrett set, a DSM TD-05 compatible set, and of course a WRX TD-04/IHI compatible set that let you bolt the turbo on and use a Stock WRX intercooler with no fancy pipe-work. Should have my first prototype set made in the next few weeks...I hope.
-Brad
ChicksDigWagons is offline   Reply With Quote
Old 06-30-2003, 10:11 AM   #11
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Brad, not worth it. The VF11 is also too small for the EJ25 and the swap just wouldn't be worth it.
Old 07-01-2003, 01:06 AM   #12
ChicksDigWagons
Member#: 20508
1998 Red Wagon
I didn't say it would be a good swap, just that it should fit. lol.
-Brad
Old 07-01-2003, 09:20 AM   #13
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Old 07-01-2003, 08:51 PM   #14
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Revision is offline   Reply With Quote
FS: custom up and down pipes for 2.5RS-T RickInLittleElm TXIC Private Classifieds 0 04-13-2006 05:36 PM
Custom Up and Down pipes for2.5 RS-T RickInLittleElm Private 'For Sale' Classifieds 0 04-13-2006 04:46 PM
HKS Uppipe and Down Pipe? SjpWrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-02-2003 04:25 PM
uppipe and down pipe with stock muffler?. wrex03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-24-2002 07:25 PM
Custom up and down pipes Wannabeturbo Normally Aspirated with bolt-on Forced Induction Powertrain 5 07-30-2001 02:05 AM
