Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 06-24-2003, 12:47 PM   #1
wrxlvr
Member#: 10788
2016 F150
Blue Jeans
Default Borla Headers question
A friend just bought an '01 Outback Limited Sedan.
1. Will the Borla Headers fit?
2. Will they bolt up to the rest of a stock exhaust?
3. How much power would he make using just the headers?
4. How much power with headers + Cobb Tunings catback?
wrxlvr is offline   Reply With Quote
Old 07-09-2003, 07:03 PM   #2
rubberman
Member#: 28881
2005 LGT wagon
BSM Stage 2.5
wrxlvr,
I have a '00 Outback and put the Borla headers on several months ago. Factory headers had developed a crack/leak, so I made the upgrade instead of spending money on the same crappy factory part.
No problems with fitting up to the stock cat/exhaust system. I would recommend replacing the exhaust gaskets when you do the swap though. Took me about 2 hours for the whole swap, getting out tools/ramps, and putting everything up.
I did remove some of the bolts on the heat shielding on the cat section to make it easier to get to the header to cat bolts.
A breaker bar for those stubborn bolts saved my butt, anti-seize when putting them back on is recommended in my book.
The tone of the engine is much better at around 4-5k rpm, really brings out the boxer sound. I can feel a little difference in the car after the install, most notably on high end now.
drop me an email if you have any other questions,
Wes
[email protected]
rubberman is offline   Reply With Quote
Old 07-09-2003, 10:09 PM   #3
Rowdy2.5
Member#: 7005
2000 2.5 RS
SM and Anthrocite
is the GC8 borla header 4-2-1 or 4-1-1?
Rowdy2.5 is offline   Reply With Quote
Old 07-20-2003, 11:47 PM   #4
Russell Rogers
Member#: 27261
I'm Ron Burgundy?
it goes from 2 separate on each side to 1 on each side to 1 altogether.
ll ll
l l
l
l
kinda like that.
Russell
Russell Rogers is offline   Reply With Quote
Borla Header Question wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-04-2004 12:40 PM
Borla Header question piker28 Normally Aspirated Powertrain 15 04-06-2004 09:55 PM
Borla header question bheinz57 Normally Aspirated Powertrain 27 08-08-2003 09:29 AM
Borla Headers question wrxlvr Legacy Forum 19 06-27-2003 01:49 AM
Borla Header Question subachad Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-02-2001 01:33 PM
