Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 06-24-2003, 05:47 PM   #1
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Default Stg.2 Map UTEC help
Here is the fuel map, this is the way it came loaded from turboxs I have not touched it yet. It looks different from the stg.2 map I downloaded from their website so i was wondering what you guys though of it.. excuse me if it comes out looking weird because it does right now but maybe it will look different when I post it.
Fuel Map
Code:
[0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]      [0]
      [0]    [0.5]    [0.5]    [0.5]    [0.5]    [0.5]    [0.7]    [0.8]    [0.9]      [1]      [1]
      [0]    [1.5]    [1.5]    [1.5]    [1.5]    [1.5]    [1.7]    [1.8]    [1.9]      [2]      [2]
      [0]    [0.5]    [0.5]    [0.5]    [0.5]    [1.1]    [1.1]    [1.1]    [1.1]    [1.2]    [1.3]
      [0]    [0.2]    [0.2]    [0.2]    [0.2]    [0.2]    [0.2]    [0.3]    [0.4]    [0.5]    [0.6]
      [0]    [0.3]    [0.3]    [0.3]    [0.3]    [0.3]    [0.3]    [0.4]    [0.5]    [0.6]    [0.7]
    [0.5]    [0.5]    [0.5]    [0.5]    [0.5]    [0.5]    [0.5]    [0.6]    [0.6]    [0.8]    [0.8]
    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.9]    [0.9]    [0.9]    [0.9]
    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.8]    [0.9]    [1.1]    [1.1]
    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.9]      [1]    [1.2]    [1.2]
PaulRex is offline   Reply With Quote
Old 06-24-2003, 05:50 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Let me try the ignition map now, this map I DID mess around with, so far no knock at all, doing 4th gear pulls to near redline.
Code:
[-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]     [35]
   [-100]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]     [30]
   [-100]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]     [27]
   [-100]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]     [25]
   [-100]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]     [20]
   [-100]     [20]     [17]     [17]     [17]     [16]     [16]     [18]     [19]     [19]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [18]     [18]     [18]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [18]     [19]     [19]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [20]     [20]     [20]     [20]
   [-100]     [20]     [19]     [19]     [19]     [18]     [18]     [21]     [21]     [21]     [21]
   [-100]     [21]     [20]     [20]     [20]     [19]     [17]     [21]     [21]     [22]     [21]
   [-100]     [21]     [21]     [21]     [21]     [20]     [17]     [23]     [23]     [23]     [23]
   [-100]     [22]     [22]     [22]     [22]     [21]     [19]     [24]     [24]     [24]     [24]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [24]     [24]     [24]     [24]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [24]     [25]     [25]     [24]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [25]     [25]     [25]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [25]     [26]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [25]     [26]     [25]     [25]
Old 06-24-2003, 05:52 PM   #3
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Default Re: Stg.2 Map UTEC help
When posting things like tables and UTEC logs and maps it is MUCH easier to read if you use the code tags
(code) and (/code) before and after (of course use brackets instead of parens)
It will preserve spaces that way.
Here's an example from part of your fuel map:
Code:
Concillian is offline   Reply With Quote
Old 06-24-2003, 05:55 PM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Oh ok, so before i copy the map to the post I put in
Code:
 the map
just like if I was to post an image? let me try it out now thanks..
I guess knowing what mods I have might affect any advice as far as tuning goes so here:
Engine+related:
Samco IC hoses /radiator hoses
K&N panel filter with resonator mod
GFB pullies
JUN flywheel and some STI clutch parts etc.
Grp. N engine/tranny mounts <--(will these induce false knock reading?)
Perrin upipe
Stromung 2.5inch catless turboback w/highflow muffler
Sti hoodscoop
NGK copper one step colder plugs
Gauges:
Greddy EGT +boost
Old 06-24-2003, 08:54 PM   #5
Mildmanneredman
Member#: 29962
There are 2 versions of the stage 2 map. One for 93 octane and one for 91 octane.
Mildmanneredman is offline   Reply With Quote
Old 06-24-2003, 09:11 PM   #6
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
I wonder if the stg.2 map loaded on my UTEC was for 91, I know there were two versions.
Well I guess it doesn't matter anyway since I've already begun changing the maps to a more aggresive tune with success so far. I've only had the UTEC for a day though so I'm really only messing with the ign. timing and boost for now. I don't think I'm going to touch the fuel map unless you guys see anything wrong with it
Old 06-24-2003, 09:52 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
That IS the 91 Octane Stage 2 map. If you are on 93 octane, I'd re-start with that map.
The fueling is dramatically different between the two. Obviously the 93 octane map runs leaner.
Old 06-25-2003, 12:08 AM   #8
digitaltekniq
Member#: 18029
With the exception of the motor mounts/flywheel/pullies I am at pretty much the same state of mods
You're welcome to have a copy of my stage 2 93octane map, PM me and I'll email it to you.
(standard "i take no responsibility" disclaimer applies of course )
digitaltekniq is offline   Reply With Quote
Old 06-25-2003, 03:02 AM   #9
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
It is the 91octane map, oh ok that makes sense.
I just made some minor changes to the timing, and boost map tonight and man does the car pull hard. I raced my freinds Evolution last night and I only pulled half a car on him by 110mph, but tonight after I made the changes I had almost a car and a half on him going from the same mph/gear. Maybe it's other factors whatever Still fun
I'm going to try and load up my map in a few minutes when my laptop battery is done charging. I'm having so much fun tuning and datalogging I should have bought the utec sooner it much more fun than just bolting on some mod IMO.
Old 06-25-2003, 09:45 PM   #10
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Default Changes made 6/26/03
Code:
Map Name:-[Stage2]
Map Comments:-[94octane]
Fuel Map
      [0]    [1.5]    [1.5]    [1.5]    [1.5]    [1.5]    [1.7]    [1.8]    [1.9]    [1.9]    [1.9]
      [0]    [0.5]    [0.5]    [0.5]    [0.5]    [1.1]    [1.1]    [1.1]    [1.1]    [1.1]    [1.2]
      [0]    [0.5]    [0.5]    [0.5]    [0.5]    [1.1]    [1.1]    [1.1]    [1.1]    [1.1]    [1.1]
    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.7]    [0.7]    [0.8]    [0.9]
    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.8]    [0.8]    [0.9]
    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.7]    [0.8]    [0.8]    [0.9]      [1]
    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.9]    [1.1]    [1.1]
    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.8]    [0.9]    [0.9]    [1.1]    [1.1]
Timing Map
   [-100]     [25]     [25]     [25]     [25]     [25]     [25]     [26]     [25]     [25]     [25]
   [-100]     [20]     [20]     [20]     [20]     [20]     [20]     [21]     [20]     [20]     [20]
   [-100]     [20]     [17]     [17]     [17]     [17]     [17]     [20]     [19]     [19]     [18]
   [-100]     [18]     [17]     [17]     [17]     [17]     [17]     [20]     [19]     [19]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [20]     [19]     [18]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [20]     [19]     [19]     [18]
   [-100]     [18]     [17]     [17]     [17]     [16]     [16]     [21]     [21]     [20]     [20]
   [-100]     [21]     [20]     [20]     [20]     [19]     [17]     [23]     [24]     [22]     [21]
   [-100]     [21]     [21]     [21]     [21]     [20]     [17]     [24]     [24]     [23]     [23]
   [-100]     [23]     [23]     [23]     [23]     [22]     [22]     [25]     [25]     [25]     [24]
   [-100]     [23]     [23]     [23]     [23]     [22]     [24]     [25]     [25]     [25]     [24]
   [-100]     [23]     [23]     [23]     [23]     [22]     [26]     [26]     [26]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [26]     [26]     [26]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [27]     [27]     [27]     [27]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [28]     [28]     [27]     [27]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [27]     [27]     [27]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [27]     [27]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [27]     [26]     [26]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [27]     [26]     [25]     [25]
   [-100]     [25]     [25]     [24]     [24]     [23]     [23]     [26]     [26]     [25]     [25]
Boost Map
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [85]     [85]     [95]     [95]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [82]     [82]     [92]     [92]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [78]     [78]     [88]     [88]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [70]     [70]     [81]     [81]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [70]     [70]     [80]     [80]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [65]     [65]     [77]     [77]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [70]     [70]     [85]     [85]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [70]     [70]     [86]     [86]
      [0]      [0]      [0]      [0]      [0]      [0]      [0]     [70]     [70]     [82]     [82]
Old 06-26-2003, 02:40 AM   #11
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Cool BUMP
Above are the newest map I am running.. The car pulls smooth and very strong I'm very happy with the progress I've made with the UTEC.
Peak boost is about 17psi when it's colder outside like at night time today.
Havn't had any knock, or flashing CEL. I checked with some dataloggin also and no knock.
I'm not sure where to go from here. If I try to advance the ignition anymore is it worth it? Any tips? This is the first time I've tried to tune a car before..
Old 06-26-2003, 08:55 AM   #12
Rich10
Member#: 14934
You should really change your boost mapping to closed loop. You'll see faster boost (especially in the lower gears) and more consistent boost levels.
Rich10 is offline   Reply With Quote
Old 06-26-2003, 11:53 AM   #13
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Hmm.. I'll have to make another map and try it out when I have time. But that means that I wouldn't be able to switch between maps using my map switch right, because then I would have to go to the parameter file and change the boost setting to closed.
Old 06-26-2003, 12:49 PM   #14
Rich10
Member#: 14934
First, go to your parameters (special constants) and change to closed loop. I also changed the boost control gain from 50 to 46 to help the turbo boost quicker (although this can lead to boost spikes). Then change your boost map. I started at about 225 and worked up from there at increments of approx 25. Most people end up at around 330 to get 16psi. I needed about 400 with 2 turns of the ABC to get 16.5psi. Once you create several maps, you can still switch maps using the map switch. I have maps at 12psi, 14psi, 16.5psi, and 16.5psi with leaner fuel/air ratios.
Old 06-26-2003, 12:59 PM   #15
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Cool, thanks.
How does my ignition and fuel map look? And if I try to advance the ignition anymore would it be worth it?
Old 06-26-2003, 02:03 PM   #16
digitaltekniq
Member#: 18029
Paul,
I'm sending you my OLB map tonight for you to look at - I am going to tune a CLB map this weekend, I need to tune another that is happier with the AC running (given it's getting a little warm in TX now ). My current map bogs a little too much for my liking.
CHeers
Rich
Old 06-26-2003, 02:16 PM   #17
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
yeah it's about 90F here now too. I just don't go into boost until night time now .
I'll take a look at that map definatly thanks..
Old 06-29-2003, 10:58 PM   #18
digitaltekniq
Member#: 18029
Paul (and anyone else who is interested)
Here's my current stage 2 OLB map - you're welcome to take a look. All standard usage disclaimers apply - this map is running slightly leaner on my car than the base TXS stage 2.
My performance mods:
- Autospeed catless uppipe
- Vishnu IC hoses
- TXS catted stealthback
- Prodrive muffler
- GFB BOV
- TXS ABC wound out 2.5 turns
My UTEC settings:
- Boost gain set to 45
- Standard TPS calibration for 0-100% , I hit 100% dead on WOT
- MAP sensor calibration is accurate -9.4psi vacuum 16.5psi at 4krpm in 4th
I am also building out a CLB map over the next couple of days, once I have it stable I'll post that up too.
Right click, save-as
Cheers
Rich
Old 06-30-2003, 04:44 AM   #19
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Thanks alot, I like looking at others peoples maps to compare. I have to load up my newest setting tomorrow, I'm running quite bit more advance though.
I'll post it tomorrow.. I tuned it on 94octane, but tonight I was runnning out of gas and the closest gas station was an exxon so I had to get 93, and I couldn't get the car to detonate at all so that is good..
Old 06-30-2003, 10:49 PM   #20
Ski Man
Member#: 5334
WR Blue
Question
Does anyone have any good explaination on the seeming vast differences between peoples closed loop mapping. I tried to deal with closed loop up to 375 and a gain down to 40, but it still only ran 13psi and spooled slower than the open map tune I have now.
I ran out of patience since my open loop mapping was running so great and consistant, figured - why bother.
Ski Man is offline   Reply With Quote
Old 07-01-2003, 08:55 AM   #21
digitaltekniq
Member#: 18029
I think you have to wind out the ABC a little more with the closed loop map - and change the boost gain to a lower value.
AP Stg. 2 vs. UTEC base map WrxRick UTEC 3 07-07-2006 04:43 PM
Ok to run base stg 2 map all the time? Stiguy247 Engine Management & Tuning 9 05-18-2005 02:41 PM
Which version Cobb stg. 2 map is better? MF-DIF Engine Management & Tuning 4 03-05-2005 12:38 PM
Can I run TXS stg-2 map with the HKS DP? Mitsuby Engine Management & Tuning 14 01-23-2003 03:43 PM
generic stg 2 map and closed loop? z&cobb Engine Management & Tuning 19 12-25-2002 02:49 AM
