Welcome to the North American Subaru Impreza Owners Club Saturday February 28, 2015
Old 06-24-2003, 07:59 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default finalizing EJ18T fuel system setup
ok, i wanna make sure i have everything i need because the fuel delivery is very crucial. here's what i got and what im looking to do. 370cc silvia injectors with a stock WRX fuel pump and a Apexi SAFC modified to read boost instead to throttle position. i read that the fuel pump needs some modifying, like using an old integra fuel pump adapter and then splicing the wires to the existing wires. i can also use the integra filter bag and change the tubing with all that to fit. or maybe i can get all the newer subaru fuel pump goodies and fabricate them to fit. i know of a 98 L sitting in my local junkyard. i just wanna make sure the fuel delivery will be safe. btw, im running a TD04 on 5 psi, if that helps, which im sure it does. any other questions about the setup, just ask, cause i wanna try to get this as right as possible the first time. thanks.
Brent
scoobyimprza is offline   Reply With Quote
Old 06-26-2003, 01:09 AM   #2
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
bump
Old 06-26-2003, 08:06 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
bump
im actually gonna assume i planned everything right, which makes me happy
Brent
Full sequential fuel system setup....questions mtcs Built Motor Discussion 2 05-14-2010 11:55 AM
need advise on how to setup a fuel rails setup. ownnij Texas Impreza Club Forum -- TXIC 7 08-20-2009 09:04 PM
Offer to mechanically inclined: my 18g/fuel/Utec setup for your stock setup, swapfest annointed Tri-State Area Forum 0 10-10-2004 12:17 AM
Custom setup w/pics: FP Green, Tial wastegate, fuel system, etc.. BassMan097 Member's Car Gallery 0 03-28-2004 02:16 AM
fuel system managment system jeffsnyder Normally Aspirated Powertrain 2 09-23-2001 02:13 PM
