Old 06-24-2003, 08:00 PM   #1
99WRXEJ20
Member#: 34545
1999 GC8
74f
Default jdm swaps done, but need to reset ecu! help
the 96 wrx swap is done but the ecu needs reset, any ideas.
thanks
99WRXEJ20 is offline   Reply With Quote
Old 06-24-2003, 11:38 PM   #2
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default Re: jdm swaps done, but need to reset ecu! help
pull the negative on the batt for 1 hr?
thanks
mcu81 is offline   Reply With Quote
Old 06-25-2003, 09:23 AM   #3
99WRXEJ20
Member#: 34545
1999 GC8
74f
thats what i figuard to do but, when i talked to the head tech at the suby dealship he said i need to use the scan tool to reset it, cause the codes burn on to a chip, and my data connecter dosnt work since the swap so i cant use a scan tool.
Old 06-25-2003, 09:26 AM   #4
Puckaveli
Member#: 1518
00 2.5RS
Well if you have CEL it would be advisable to look and see what they are. Are you using the JDM ecu or your US one?
Puckaveli is offline   Reply With Quote
Old 06-26-2003, 08:22 PM   #5
99WRXEJ20
Member#: 34545
1999 GC8
74f
fixed it!
thanks though
Old 07-02-2003, 02:12 PM   #6
2yLiTe
Member#: 660
can you share your fix?
2yLiTe is offline   Reply With Quote
Old 07-02-2003, 06:57 PM   #7
99WRXEJ20
Member#: 34545
1999 GC8
74f
i took the battery out overnight, while changing spark plugs, and in the morning when i hooked it back up the ecu reset.
I dont know, all i care about is that it reset.
sorry for the lack of info but i have none to give.
swap done.. but i have a problem..help! xtian Subaru Conversions 43 02-23-2006 06:56 PM
just installed uppipe+turboback. do i need to reset ecu?? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-21-2002 07:13 AM
Need to reset ECU w/K&N? tekriter Normally Aspirated Powertrain 6 04-06-2002 09:51 PM
Cool just got HPMBC- Dont need to reset ECU right [email protected] Texas Impreza Club Forum -- TXIC 1 01-22-2002 09:26 PM
do i need to reset ecu? kid22 Technical Forum Archive 3 05-19-2000 12:43 AM
