Old 06-25-2003, 12:24 AM   #1
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default Will My RS brakes work on a legacy wagon
my friend has a 1990 Legacy wagon and I am changing everything over on my 98 RS. He is going to take the struts, springs, etc. WIll the brake rotors from my car work on his? Will the sway bars work on his car? I know there was a website a while back that told all this stuff but I can't find it anymore.
Tattoo Collector is offline   Reply With Quote
Old 06-25-2003, 09:20 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Rotors will, brakes will work.
Sway bars will not work.
The only caution I'll give you on the struts and springs is that the RS is a lighter car and may not have as high springs rates. If you have spring rate, damping info for the RS I can check it against info for the 90.
Legacy777 is offline   Reply With Quote
Old 06-25-2003, 10:03 AM   #3
subarurabbit
Member#: 4083
2011 OB 3.6R
does he have 15" or larger wheels?
subarurabbit is offline   Reply With Quote
Old 06-25-2003, 09:20 PM   #4
Tattoo Collector
Member#: 19364
1998 Impreza RS
Black Mica Pearl
Default No 15"
It doesn't have 15" on it now, but he is thinking about going larger. He is using my rotors on his stock calipers, will that work? Also, I think that the stock spring rate for the car is like 139 and 117; something like that. I am not 100% sure, but it is very close to those numbers. His suspension is shot, so anything will make a difference I think. Thanks for the help.
Nathan
Old 06-25-2003, 10:36 PM   #5
subarurabbit
Member#: 4083
2011 OB 3.6R
14" rims will not clear calipers.
Old 06-25-2003, 11:28 PM   #6
Legacy777
Member#: 4800
Here's the info for the 1990 Legacy
Code:
1990 Legacy
Sedan - FWD
Front Spring Coefficient - 123 lb/in
Rear Spring Cefficient - 129 lb/in
Sedan - AWD
Front Spring Coefficient - 134 lb/in
Rear Spring Cefficient - 134 lb/in
Wagon - FWD
Rear Spring Cefficient - 179 lb/in
Wagon - AWD
Rear Spring Cefficient - 190 lb/in
will 08 sti brakes work on a 06 sti? my94saleen Brakes, Steering & Suspension 16 01-25-2010 11:33 AM
Will '05 LGT brakes work on a '93 or '98 Legacy with B4 rims? e28fixer Legacy Forum 3 04-20-2007 12:30 PM
Will Impreza strut tops work on a Legacy wagon? dsc Brakes, Steering & Suspension 4 12-03-2002 12:07 PM
Will FHI Version 5 Struts And Springs For An RS Also Work On A Legacy? MY99 2.5GT Brakes, Steering & Suspension 0 05-08-2001 05:24 AM
Will an RS shifter work in a Legacy OutbacK? dvancleve Normally Aspirated Powertrain 7 03-28-2001 08:56 PM
