Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 06-25-2003, 03:06 PM   #1
bdoss123
Member#: 19958
Default Click/Pop Sound While Breaking, 97 GT
Sorry I already posted this in the brakes/suspension forum, but am getting no response. Show some love legacy owners.
I have a 1997 Legacy GT and when I am braking I hear a pop, or click, coming from what seems like the front left wheel. This noise doesn't happen all of the time that the brakes are on, it is only when the brake is being pressed lightly. Therefore, when coming to a sudden stop, or a hard stop, I don't hear the noise at all, but when gradually slowing down the noise fades in as I put pressure on the pedal, and then fades out the further down the pedal goes. The click coincides with the rotation of the wheel, so when the car is going fast, it clicks fast, and visa versa. Does this sound like something is wrong with my brakes, pads, or rotors? I am clueless about brake (and suspension, although it doesn't seem to be suspension since the click coincides with rotation speed) problems so any help is greatly appreciated.
Thanks,
Brendan
bdoss123 is offline   Reply With Quote
Old 06-25-2003, 03:37 PM   #2
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I've got the same sound with my Subaru 4Pot brakes on my GT. I asked my local Subaru repair shop (very knowledgable guys). They took it for a spin and looked at it on a lift and told me that it was just the noise of the pad shifting in the caliper under breaking loads. They said it was nothing to be worried about. Apparently it doesn't happen to every subie, which annoys me, but my car stops great, so I have no complaints.
-S
monovich is offline   Reply With Quote
Old 06-25-2003, 03:40 PM   #3
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Check out your anti-rattle clips and also check to make sure you don't have a blown CV boot.
US2JDM is offline   Reply With Quote
Old 06-25-2003, 04:34 PM   #4
bdoss123
Member#: 19958
How do I check the "rattle clips" and the cv boot?
Thanks,
Brendan
Old 06-25-2003, 05:01 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
-S
Steve have you got the "t" clip that clips onto one of the pad pins and under the other? Not the whisker clips but the clip that presses down on the top edge of the pads?[4pot only question-sorry for the thread hijack.]
ss
subysouth is offline   Reply With Quote
Old 06-25-2003, 05:05 PM   #6
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Thanks,
Brendan
The anti-rattle clips in the 2pots fit between the pads ears and the caliper bracket. They sometimes make it a pain to snap the pads into the bracket. They are made of thin metal that kinda looks like stainless steel. Sometimes they get left out in a re-assembly of brake calipers. The calipers will function without them, but the pads will rattle back and forth in the caliper bracket.
Just for clarity, these are not the shims that are pad shaped and snap onto the back of the pad to prevent squealing.
ss
Old 06-25-2003, 06:20 PM   #7
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
ss
I'm pretty sure I do, is it a bronze color?
Old 06-25-2003, 07:12 PM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
yeppers.
ss
edit: I was checking again, but thats really the only anti-rattle clip on the 4pots.
Old 06-26-2003, 10:12 AM   #9
bdoss123
Member#: 19958
Appreciate the quick help. Hopefully I can get this figured out, as it annoys the hell out of me when riding through town breaking at low speeds.
Brendan
Old 06-26-2003, 01:43 PM   #10
2WD Bites
Member#: 19349
1999 Legacy GT Ltd
Black Granite Pearl
Hey Brendan,
I have the same problem with my 1999 GT. I can replicate it anytime I want by reversing and braking...and then going forward and depressing the brakes.
Dealer told me it is the pads shifting from side to side.
Apparently nothing to be concerned about.
Steve
2WD Bites is offline   Reply With Quote
Old 06-28-2003, 12:38 PM   #11
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Brendan,
How many miles on your car? If the car is stopping correctly and not pulling from one side to the other, then I'd think your brakes are operating correctly. Follow-up on some of the other responses and if those don't get you to where you need to be answer-wise, you can try jacking up the car on that side.
CAUTION: Use jack stands, block your wheels and set your emergency brake if you're going to get under the car!
Rotate just that wheel while someone lightly depresses the brake pedal for you. While the wheel is braking, listen for the noise and see if you can feel any "catch" in the tire rotation. Rotate the tire quickly backwards and have your brake operator
stop the tire from turning. Then try rotating it forward and lightly brake to see if you can pick up the catch/sound you mentioned.
Once you know where the sound is coming from, then you'll know where to direct your next inspection steps.
Also, where are you located? If you're not able to resolve this from the inputs you get on here, you also might try posting in your "area" forum and ask if someone in your area with Subaru brake experience can give you a hand. Subaru folks do that for each other.
Br, Dale
Subietonic is offline   Reply With Quote
Popping sound while turing... KevsWRX21 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-18-2010 11:07 PM
Clicking Popping sounds? Strider327 Brakes, Steering & Suspension 2 10-01-2009 07:09 PM
Transmission Click/Pop Sound - please help ajshades Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 03-18-2008 11:24 AM
Clicking/Popping Sound underneath Drivers Seat STix66 Interior & Exterior Modification 6 11-21-2006 07:44 PM
Strange clicking/popping sound.... AllWheelsDriven Car Audio, Video & Security 0 12-28-2003 12:43 AM
