Old 06-25-2003, 11:08 PM   #1
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Default 2.25" vs 2.5" exhaust question
Hello, I've not posted in this forum before and am really very new to FI stuff.
I've ordered a TWE header and cat to complement my brullen cat back, all 2.25". If I were to add a (AVO?) turbo, how much performance would you think I'd be loosing by keeping this diameter piping instead of going up to 2.5"???
THanks,
Dr Ken is offline   Reply With Quote
Old 06-26-2003, 12:01 AM   #2
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Depends on how much power you're running. 2.5" is good upto about 300bhp. so 2.25".... probably good enough for a 5psi kit without much loss. Bigger is always better with the turbo.
Midwayman is offline   Reply With Quote
Old 06-26-2003, 01:16 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Yeah. I'm a strong believer that you can never over exhaust a turbo car.
Eric SS is offline   Reply With Quote
Old 06-26-2003, 09:23 AM   #4
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2015 Outback - Croc
Dundee Edition Ice Silver
you will have to lose the headers when you turbo the car...
but yes, 2.5" would be better for boost...
DanzBorin is offline   Reply With Quote
Old 06-26-2003, 11:06 AM   #5
Avenger
Member#: 1234
Darn.. I knew I should got a 5" exhaust.
I got a 2.5" exhaust and it works fine with 8 psi.
Avenger is offline   Reply With Quote
Old 06-26-2003, 12:57 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
which tech works header did you go with? the super stock one? i was told the super stock is best for turbo applications because the high output headers are tuned more for higher end and can only be taken advantage of if you have a raised rev limit.
i am hoping to get some soon once they find out if their older version will fit an automatic. tell me what you think of it once you get it cause it looks like great craftsmanship.
i dont believe so because i was told they bolt up to the factory location so basically any of the aftermarket kits will work with it, which is sweet.
Ben
Old 06-26-2003, 02:19 PM   #7
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Yup, Super stock (2.25"), instead of the High output (2.5"). Stock end placement. There are two different ceramic coats available for its mild-steel construction: The shiny, is actually lower temperature rated, for N/A. The dull is for higher temps of forced induction, but more prone to debris chips. I chose the former, but still have time to change to the latter, if going FI with this header seems a reasonable option.
I suppose I'd be obligated to critique these headers once installed, as there are still only a few who have confessed to getting them.
I'm open to suggestions.
2.25" or 2.5" Brullen exhaust? cMags Normally Aspirated Powertrain 2 11-02-2007 12:43 PM
2.25" vs. 2.5" exhaust LandoCommando Normally Aspirated Powertrain 16 05-09-2007 01:26 AM
2.25" to 2.5" axelback? rally_on Normally Aspirated Powertrain 1 11-11-2005 09:06 PM
2", 2.25", and 2.5" blue silicon hose various lengths White 2.5rs Private 'For Sale' Classifieds 4 05-25-2004 05:31 PM
2.25" vs. 2.5" catback piping, how much low end difference? DeusExMachina Normally Aspirated Powertrain 3 04-23-2002 05:31 AM
