Old 06-26-2003, 01:53 AM   #1
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Default My Hybrid Is Alive!!
Ahh yes she's finally done. The setup is as follows:
Power Plant
Stock EJ22T with SOHC 2.5 Heads
ARP Head Studs
Exhaust
WRX Exhaust manifold
GtSpec UpPipe w/3 Extra Flanges as a spacer
WRX stock turbo back
Turbo bits
WRX Intercooler w/ Samco Hoses
Forge BOV
TD04L
JOE P MBC
Turbo Air intake made form CAI
Engine Management
Link PLus
Fuel
Stock WRX Injectors
Walbro Fuel Pump
Misc
WRX Water Pump
Jaz Catch Can
NGK 7 Plugs
ACT Clutch (Holds 304lb)
seven881 is offline   Reply With Quote
Old 06-26-2003, 01:54 AM   #2
seven881
Member#: 8828
01 BRP 2.2T Hybrid
More Pics
Old 06-26-2003, 02:02 AM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Well first of all this was one of the largest projects I've ever done. Doing an egine swap is fairly large project, but it wasn't too bad. The Block and WRX exhaust actaully we're in my trunk when I drove cross country from WI to CA. That was a crazy drive too. All in all I'm happy with most of the setup. There's still some issues with the coolant lines and heat exposure. I'll be using temp coatings to keep the temps down and a couple other tricks too.
Using the WRX setup is kind of a pain, but I can use PE or STI injectors now and the 18G or similar turbo upgrades available for the WRX. Shimming the control arms took 1 washer on each side which isn't as bad as I thought it would be. The only thing you'll need is the clamps to hold the sway bar from a WRX. I don't have those yet, but the sway bar doesn't need to be changed as far as I can tell.
Old 06-26-2003, 08:07 AM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Congrats, now how many psi are you running?
Are you planning on cams for those 2.5SOHC heads?
Revision is offline   Reply With Quote
Old 06-26-2003, 09:14 AM   #5
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Time to change your car profile " Soon To Be 2001 RST Hybrid "
Anthony C
Bobalouy is offline   Reply With Quote
Old 06-26-2003, 09:21 AM   #6
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Default Wohoo
Good job man. Nice to see another get done. I've been slacking on mine. Remodeling house and all. How's your lowend off boost?
Later, Tod
todnar is offline   Reply With Quote
Old 06-26-2003, 10:12 AM   #7
dyswtric27
Member#: 404
2000 Audi S4
endless.night
very nice, hows it running so far?
Why did you have to shim the control arms, i have not followed what you have been planning. Also how did you get the wrx injectors to fit in the intake manifold? Which mani are you using anyways? Sorry to drill you with questions its just a sweet looking setup and i want to steal all your ideas.
dyswtric27 is offline   Reply With Quote
Old 06-26-2003, 11:04 AM   #8
Avenger
Member#: 1234
Nice.. but how come on the last picture the swaybar bushing bracket looks mangled and the bushing is almost off?
Avenger is offline   Reply With Quote
Old 06-26-2003, 11:06 AM   #9
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I'll be running up to 15 PSI on the TD04L. I'm taking it to I-SPeed soon and they'll be doing all the tuning. I'll have a dyno plot when all done to post. It's only boosting to 5 right now, but I have the MBC set to pull most boost until it's tuned and I may have a leak. I'm still woking out some little things.
Old 06-26-2003, 11:08 AM   #10
seven881
Member#: 8828
01 BRP 2.2T Hybrid
I need a new bracket for the swaybar, the other side is fine. The WRX crossmember has a different bolt pattern for the bracket. I can hear it clunking sometimes, but I only driving it short distances for now.
Old 06-26-2003, 11:13 AM   #11
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Right now it's running fine, only 5 PSI, but I'll change that soon. I did shim the control arms with 1 spacer, see the pic above. I used the Rev-Lab injector adapters, but I have to bore out my intake manifold and drill out the adapter to make it fit since they we're milled wrong. I'm using the stock EJ25 manifold. Steal away these aren't any big secrets.
Old 06-26-2003, 02:54 PM   #12
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Thank you for the picture of the control arm spacers. I needed to see that
-Jon
Old 06-26-2003, 03:10 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
-Jon
agreed
Old 06-26-2003, 03:50 PM   #14
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Thumbs up Excellent!
Lovely setup man! Enjoy it glad to see it is up and running...
I will be doing the same thing, but I am going to slap in the WRX aluminum control arms.
They do fit, with perfect alignment too. I just don't know why people say they don't fit cause I have seen them on a Old School RS chassis :P.
enjoy man!!!
Kevin
latinskllz is offline   Reply With Quote
Old 06-26-2003, 04:06 PM   #15
seven881
Member#: 8828
01 BRP 2.2T Hybrid
Cool, when people talk about slop in the arms, I was expecting more than one washer per side.
-Jon
Old 06-26-2003, 04:18 PM   #16
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
Thats almost exactly the same as my setup except Im running the stock block. Looks nice. I'm interested to see how the td04 does with 15psi. I am alternating between 6psi and 10psi on mine. Also, Im still using my RS sway bar with the WRX brackets and it works fine. I was planning on getting the WRX sway bar but Im finding I dont really need to. It doesnt make any odd noises or anything. What do you have running off the turbo to the intake?
Surb00 is offline   Reply With Quote
Old 06-26-2003, 04:37 PM   #17
seven881
Member#: 8828
01 BRP 2.2T Hybrid
The HP & Torque should be a little higher than a stock WRX since I have .2L extra displacement. My ET's should be lower too since I'm 500 lighter too, we'll see though.
Yeah, I just need the WRX brackets and everything else should be fine. I've seen some posts about it rubbing or not fitting at all, but mine appears to be fine. Also, someone said that the downpipe won't fit because it's sits to low. Well, mine fits, but the stiock hanges don't line up which isn't that big of a deal.
I think some of this mis-information needs to be cleared up or confirmed. Feel free to ask any questions.
My book is alive... what is it??? rallyedan Off-Topic 21 04-17-2008 05:59 AM
Dilbert is alive and well at my office - offensive email signtaure banned! Jessie James Off-Topic 17 09-07-2002 04:48 PM
Frankenstein is alive...alive... TaiChih Mid Atlantic Impreza Club -- MAIC 19 07-24-2002 09:32 AM
My RS is ALIVE! Travis R Texas Impreza Club Forum -- TXIC 2 01-23-2001 05:26 PM
