Old 06-26-2003, 08:56 AM   #1
james_gt
Member#: 20852
1995 Impreza L
Red
Default got my new 2.2l turbo
I picked up a 2.2 liter turbo motor from a legacy. I got the engine, turbo, larger radiator, full wiring harness, uppipe and downpipe for 900 dollars. My main question is for anyone who has swapped one of these into their cars. I have a 95 L and if anyone could give me any suggestions. He said the only thing i will need is a crossmember. Thanks for any help.
james_gt is offline   Reply With Quote
Old 06-26-2003, 11:11 AM   #2
95urabus
Member#: 38418
1995 Impreza
Bright Green
What kind of horsepower is that engine capable of?
95urabus is offline   Reply With Quote
Old 06-26-2003, 11:19 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thats a pretty good price . .there are a few around that have done it ..
Old 06-26-2003, 12:27 PM   #4
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
James,
well for starters, u need to make sure fuel delivery is ideal, so make sure u have the right fuel pump. do u have the ECU? if not, you'll need some electronics to map the fuel delivery because you're 1.8 ECU is programmed for one-dimensional fuel delivery. do u have the exhaust manifold with the uppipe? if not, you'll need that, make sure u get the right setup if you're single or dual port. you'll need the rest of the legacy exhaust to bolt onto the downpipe. are u running any intercooler? also, if this is the VF10 turbo, you cant run more than 15 psi, so make sure u have proper boost control also. good luck.
Brent
scoobyimprza is offline   Reply With Quote
Old 06-26-2003, 02:44 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
oh yeah, and i forgot. when u get the crossmember, make sure u get a swaybar that will work with it. that'd be either the legacy turbo sway bar or the JDM GC8 turbo sway bar.
Brent
Old 06-26-2003, 11:26 PM   #6
james_gt
Member#: 20852
1995 Impreza L
Red
why i thank you very much brent. You werent supposed to see this because i didnt want anyone around to know. But you seem to know a lot. Maybe you can help with a few steps of the process. I have the entire exhaust and intake system with ecu and ALL wiring harnesses. I do not have an intercooler yet but am getting one. thanks.
James
Old 06-27-2003, 12:54 AM   #7
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
alright, looks like you're pretty much set to go. all u need is the crossmember with the swaybar, fuel pump, intercooler and all the hoses, and the BOV. make sure u use a circulating valve for the MAF. does the ECU control to wastegate? im gonna assume its a VF10. if the ECU doesnt, you'll need a boost controller. if u still have my cell number, call me up next week to come over and check it out and i'll make you a list of everything, if not, just PM me. later.
Brent
Old 06-27-2003, 08:34 AM   #8
james_gt
Member#: 20852
1995 Impreza L
Red
Cool. I dont think i still have your cell but i will pm you later.
Old 07-07-2003, 06:40 PM   #9
imposter
Member#: 10642
95 Impreza EJ22T
I just did this in my 95 impreza. Wiring diagrams are a must have as well as patience. You will also need the legacy cooling fans and recovery tank. Dont get a USDM wrx intercooler b/c its too big. Few have made it fit but you must ditch or reroute the a/c and the endtank rubs the firewall. Go to the intercooling forum at www.legacycentral.org to see some of their setups. Be prepared for some minor things to come up as well; they always do.
-Jim
imposter is offline   Reply With Quote
Old 07-07-2003, 08:03 PM   #10
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
-Jim
u can cut a little of the throttle body and intercooler to make it fit, no biggie at all
Old 07-09-2003, 11:51 PM   #11
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
i have an ej22T in my 95 legacy. if you are going to do any mods do them now, while the motor is out. go to www.rslibertyclub.org and look for a v2 sti air to air ic, its the easiest way to ic an ej22T. also look into getting some type of aftermarket ecu. your car will run with the 1.8 ecu but it will be so damn rich that unbrunt fuel will come out of your exahust.
get a downpipe for a wrx. the legacy turbo dp has a big cat on it. this cat heats the motor up a great deal. look into the hks its only about 150 and has done good for all of the legacy turbo guys.
i am having a harness made so that i can plug the ej22T ecu into my 95 harness, this is the easiest way to do it but not the best. its very expensive, many signals have to be changed and redone.
is it an auto? if so look into getting a tcu from a legacy turbo. your car will hold shift points for much longer then needed with this motor.
good luck and have fun.
subiekid is offline   Reply With Quote
Old 07-10-2003, 11:31 AM   #12
subiekid
Member#: 25516
i forgot to add, no mater what you do you will be running 6 lb of boost because the waste gate spring is set to 6. so even if you dont run a boost controller you will still be able to get 6 psi.
Old 07-10-2003, 12:01 PM   #13
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
thats a minimum of 6psi ... not a max..
althought you may be able to bend the actuator to open sooner and reduce boost more...
any wrx intercooler 93-96 will do
Old 07-16-2003, 01:41 PM   #14
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
-Jim
Jim has since installed teh USDM WRX intercooler with minor issues. It works well. It's now running 10 PSi on the stock Legacy turbo & runs like a champ! I'm sure the HKS DP & Stromung 3" catback help!
omahasubaru is offline   Reply With Quote
Old 07-17-2003, 10:27 AM   #15
james_gt
Member#: 20852
1995 Impreza L
Red
Man guys, Thanks for all the help and info. Im thinkin it should go smoothly since I have some people helping me including a kid that had one in his car for a short period of time. Thanks again.
James
Old 07-17-2003, 11:44 AM   #16
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Brent
A USDM WRX wagon swaybar should work, too. Might be a little easier to find as well.
- Trent
peepshow is offline   Reply With Quote
Old 03-30-2005, 03:47 PM   #17
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
Question questions on old thread
front sway bar were they talking about with the legacy 2.2t crossmember?
What happens if I have a custom kit that has a custom downpipe utilizing my existing crossmember (1.8).. if I put an ej22t block in will I still need that cross member?
Please answer both questions
jkjersey is offline   Reply With Quote
Old 03-31-2005, 10:44 AM   #18
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
The swaybar, you can use any of the WRX front swaybars.
2nd question, you can still use your crossmember with the EJ22T block.
anyone destroked a 2.2l turbo motor to 2.0 l? HighWayDrifter Subaru Conversions 38 07-05-2010 09:39 PM
Need to buy a new 2.2L Turbo Motor Killion22 Pre-2002 Factory Turbo Powertrain 5 07-01-2007 10:13 PM
got my new muffler today, should i go 2.25" or 2.5" herzy2.5RS New England Impreza Club Forum -- NESIC 9 05-30-2001 08:20 AM
turbo on my 98 2.2L ?? Need help SYMSWRX Normally Aspirated Powertrain 1 05-02-2001 10:59 PM
2.2l turbo block and 2.5l heads Jessie James Normally Aspirated Powertrain 12 01-23-2001 08:34 PM
