Old 06-26-2003, 03:51 PM   #1
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Default Not hitting full boost, is it the turbo?
I have a T3/T4 turbonetic turbo with 440cc injectors and LinkPlus E.M. and a supra fuel pump and 3in. exhaust. Anyway, when i floor it, i dont reach full boost (only 6psi) until about 5kRPM or higher. Should i get my turbo rebuilt? Would that solve/help this problem? My car was dyno-tuned last year, but its always taken a while to hit full boost, just seems to be getting a bit worse. The turbo is about 3 years old. Thanks in advance.
Sid
GimmeScoobySnacks is offline   Reply With Quote
Old 06-26-2003, 04:09 PM   #2
Surb00
Member#: 27132
1999 2.5 RS-T
Rally Blue
What kind of wastegate are you using? Is it a Deltagate? I would think it would probably be the wastegate instead of the turbo(hopefully).
Surb00 is offline   Reply With Quote
Old 06-26-2003, 04:10 PM   #3
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Forgot to mention that, it is a turbonetics deltagate. Is that more likely the "culprit"?
Old 06-26-2003, 04:11 PM   #4
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Which wastegate are you running? You may need to replace your gaskets on the wastegate (both of them). Also do you have Link controlling boost or are you running just the spring?
I'm willing to bet its the gaskets cause I had the same problem. As mentioned before on this borad get the gaskets made for the Deltagate Wastegates.
This will help you out:
http://www.roadraceengineering.com/f...andgaskets.htm
WRC 555 is offline   Reply With Quote
Old 06-26-2003, 04:17 PM   #5
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Another thing i forgot to mention, i have a MBC and i know they can drift low, but i can hit 6psi which is where it is set it just takes a while.
Thanks for the tip, i think i will try that. That place is only like 20 minutes from me too!
Old 06-26-2003, 04:19 PM   #6
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
The deltagate could be the problem
Get a Tial 35mm and a 2-port boost control solenoid from Link (expensive one) and you'll have lots of fun
Old 06-26-2003, 04:29 PM   #7
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
I'm short on money, do you think the gasket can be a temporary fix? Where did you get your solenoid from and how much? Thanks.
Old 06-30-2003, 10:41 PM   #8
GimmeScoobySnacks
Member#: 2094
1999 2.5 RS-T
RBP
Old 07-01-2003, 01:00 PM   #9
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
The solenoid was purchased from AMR last year..I think at that time the price was around $250.
The gasket leak could be the problem. Check for leaks first on both ends of the wastegate. If you feel any leaks specially where the wastegate is bolted to the up-pipe that could be your problem.
If not then its time to get a Tial
ej20g, with 16g turbo not hitting full boost till 4500rpm GregBolby Factory 2.0L Turbo Powertrain 5 03-17-2010 02:01 AM
not hitting full boost. timjgx Factory 2.0L Turbo Powertrain 21 04-11-2006 07:37 AM
Not hitting full boost after silencer delete BigWrecKs Newbies & FAQs 5 03-20-2006 12:44 AM
Not hitting full boost help AshyLarry Factory 2.0L Turbo Powertrain 2 02-15-2006 08:39 PM
reasons for not hitting full boost nabiljamali Factory 2.5L Turbo Powertrain 7 02-06-2006 10:08 PM
Message Board Statistics All times are GMT -4. The time now is 07:44 AM.
