Old 06-30-2003, 11:03 AM   #1
madcow
Member#: 15071
2004 WRX Sedan
Default 04 1st time...advice please...i cant launch right
First time at the track with my 04. Only mod is HKS exhaust (17" rota actions if that matters)
I cant figure out how to launch this thing man. I didnt want to dump the clutch pegged at 6 or whatever. I read alot on here and tried different things. Heres my results. I had my 12 sub box in the back also.
My first 3 runs went 15.6, 15.5 and a 15.2..
The last run I made with a passenger since i wasent expecting much better but to my surprise got a 14.8. 3rd gear was almost at redline when i went across the finish line.
Reaction: .958
60' : 2.0
ET: 14.8
MPH: 91
I really think I can get into the low 14's with some more practice. Any advice would be appreciated. I am planning a down pipe and COBB chip as soon as the maps are complete. I wondering what i should expect for times with that setup.
Thanks
-mark
madcow is offline   Reply With Quote
Old 07-01-2003, 03:00 AM   #2
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
your 60' could be better. Even my little 2.5 RS can make it in under 2 seconds. i am no expert though. I'm just giving a free bump basically.
Dolphin Overton is offline   Reply With Quote
Old 07-03-2003, 10:05 AM   #3
madcow
Member#: 15071
2004 WRX Sedan
Idea's anyone?
Old 07-03-2003, 10:22 AM   #4
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
i find that pumping the gas between 4k-5k then slipping it out a little then when your rolling about 5mph(you really dont have to look you'll know when your there) just dump it out all the way and you'll be trown back in to your seat. ive got the same mods as you except 17in rims and i managed to pull 14.4. hope this helps
oh it takes practice you'll know your doing it right when you dont smell your clutch
SjpWrx is offline   Reply With Quote
Old 07-03-2003, 10:25 AM   #5
subi04
Member#: 34363
04 WRX
12.5@110
You should made at least 14.6. Launch at 6000 and make power shifting (throw the gears with the gas down) if you are not very skilled with this, try to make it in 2nd gear at least, this is very important because you are maximazing the power of the launch. For me 2nd is easy, just synchronize the shifting with a very fast pressing and releasing of the clutch.
subi04 is offline   Reply With Quote
Old 07-03-2003, 09:31 PM   #6
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
Post hmmmmmm,
Don't speed shift.....
SjpWrx: i use that technique, i do better when i do not watch the tachometer.
ChristophWRX is offline   Reply With Quote
Pulling My Motor Made A Little Booboo Please Help This Is My 1st Time Doing This ChrisNJ69 Service & Maintenance 5 05-10-2010 09:57 PM
Advice for a soon to be 1st time firearm owner memma Off-Topic 65 04-08-2010 05:10 PM
Give advice for 1st time at strip subenerd Proven Power Bragging 13 07-18-2005 01:02 PM
Help! Need tips/advice for 1st time to drags! AzWRX1 Proven Power Bragging 14 12-31-2002 02:59 PM
1st time at the track....please help !!! WR_eXe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 02-07-2002 04:13 PM
