Old 06-30-2003, 05:12 PM   #1
Cjchaps
Member#: 3181
07 Rav4
Default Can you recharge a 12 volt motorcycle battery with a 12 volt car charger?
I have a 12 volt battery for a scooter, and I need to recharge it, but I don't have a recharger for it. The battery itself is about the size of a coke can(but square). Can I recharge it, or will it blow up?
Cjchaps is offline   Reply With Quote
Old 06-30-2003, 06:14 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
It depends on what kind of battery it is, lead acid, NiMH, NiCD, and so on, if itís just a lead acid type, then you can charge it, but charge it on a low amp setting
Shane
PARANOID56 is online now   Reply With Quote
Old 06-30-2003, 06:50 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Most likely it's a sealed gel-type lead acid battery. These usually have the charging current stamped on them and you definitely don't want to overcharge it. If you have a big-ass car battery charger it might be too much for it but a smaller one may be ok. Monitor the charging current and don't let it go higher than an amp or so. If the battery starts getting hot, disconnect it.
Contact the manufacturer of the scooter and see if they can give you any info, or perhaps sell you a charger.
Old 07-01-2003, 01:55 PM   #4
jeffm
Member#: 34478
2003 Baja
yellow!
I do this for my bike batteries; it's fine.
However my charger has a 1/5/15 amp setting and I always use 1.
If they're lead acid, take the caps off and lay a rag on the battery. Make sure the water levels are ok (it rises as the battery charges, but don't think you can charge one that's half empty).
You shouldn't have to babysit but I never leave it a half hour without checking (I'm paranoid). Watch the battery voltage and water level.
jeffm is offline   Reply With Quote
can you vta the PCV and valve covers with blow thru ? Bad Noodle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 06-25-2015 03:55 PM
Can you find the owner of a TV with the serial number? Sephro Off-Topic 8 11-06-2007 06:26 PM
Can you tell me if anything is wrong with this picture? xdrian Brakes, Steering & Suspension 21 05-29-2007 06:23 PM
How can you steal a F50 and get away with it?! twotacosfor99cents Off-Topic 23 09-26-2003 04:02 PM
Can you replace a cracked STI headlight lense with a US OEM lense? Code-7 Interior & Exterior Modification 2 10-23-2002 11:15 AM
