Old 06-30-2003, 06:01 PM   #1
Imprezd
Member#: 3357
Default USDM ej20 vs. Usdm ej18 Flywheel
Does anyone know the differences between the flywheels?
Imprezd~
Imprezd is offline   Reply With Quote
Old 07-01-2003, 02:19 AM   #2
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Besides the fact that they are uncompatible?
Well, the ej18 flywheel aparently has a different offset, and is also a less complicated flywheel and weighs about 10lbs less. (learned this via when I had my flywheel and clutch replaced)
Old 07-01-2003, 07:13 AM   #3
Imprezd
Member#: 3357
what did you end up using for a flywheel & clutch setup?
Old 07-01-2003, 11:16 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
abit of clarification please
the flywheels are not interchangeable -to the clutch
afaik there are 3 types of subaru flywheel/clutch
#1 push friction disk is 8 1/2 wide (most all cable based manuals)
#2 push friction disk is 8 7/8 wide (most hydrolic manuals)
#3 pull - legacy turbo,wrx,STi,forester XT (see a pattern?)
Old 07-01-2003, 04:26 PM   #5
Imprezd
Member#: 3357
Good info... Jaxx..
Just one question though i thought that the WRX was Push since the the Slave pushes the clutch lever..
Hmm but at the same time it would percieved to be Pull because it pulls the TOB from the clutch.
Basically i am trying to get clarification on will the WRX flywheel and clutch work with the 1.8 tranny.
I know i will have to convert it to the Same type of hydraulic system.
Thanks,
Imprezd~
Old 07-01-2003, 06:08 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hmm dunno for sure but i belive
i believe that all you have to change clutch forks and slave cyl
correct
actaully no.. you don't
you can use either push setup as long a you use the entire system
flywheel/presure plate/clutch/tob/clutch fork
if you want to use the wrx clutch/flywheel combo you will tho
after much tribulation i am using an RS flywheel with an upraded exeedy clutch with an cable clutch fork and cable linkage
Old 07-01-2003, 10:08 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I asked this question a few months ago and now know that the push type clutches must use the the push type trannies and that the pull type and suppose to use the pull type. I am looking to do the engine swap and am going to be using the ej18 flywheel and ACT clutch for the push type engines. It is suppose to bolt right up to the engine.
Hope this is helpful,
Micah
JDM vs USDM EJ20 gimpster Normally Aspirated Powertrain 28 06-02-2016 04:02 AM
Jdm gc8 Ej20 Vs Usdm Gd8 Ej20 majik16106 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-27-2011 02:56 PM
Version 7 vs. USDM EJ20 Intake Manifold? D-Speed 2.5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-16-2005 01:07 AM
Will a AT from a Legacy Turbo fit a FWD ej18 or USDM ej20? Mr.Freeze Transmission (AT/MT) & Driveline 2 01-06-2003 05:04 PM
ej22 vs usdm ej20 STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-15-2002 03:16 PM
