Old 04-24-2001, 07:37 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post Pictures of My Money Pit's engine bay (JC Sports GB Turbo)
Here it is, not to pretty but it gets the job done.
Joshua
Subaru Salesman
<IMG SRC="http://albums.photopoint.com/j/View?u=1658522&a=12705026&p=47218613&Sequence=0&re s=high" border=0>
<IMG SRC="http://albums.photopoint.com/j/View?u=1658522&a=12705026&p=47218605&Sequence=0&re s=high" border=0>
<IMG SRC="http://albums.photopoint.com/j/View?u=1658522&a=12705026&p=47218599&Sequence=0&re s=high" border=0>
<IMG SRC="http://albums.photopoint.com/j/View?u=1658522&a=12705026&p=47218594&Sequence=0&re s=high" border=0>
yebokmj is offline   Reply With Quote
Old 04-24-2001, 08:17 PM   #2
direwlf
Member#: 1479
1999 Impreza 2.5RS
Silverthorn Metallic
Post
Definetly not pretty by any stretch of the imagination. Is it half as functional as it looks? And hows the performance?
direwlf is offline   Reply With Quote
Old 04-25-2001, 06:25 AM   #3
yebokmj
Member#: 2213
Brilliant Red
Post
It's a 100% functional, and the performance is neck snapping. It is still running rich due to O2 sensor problems so more power is on it's way.
Joshua
Subaru Salesman
Old 04-25-2001, 06:32 AM   #4
Damon
Member#: 2902
Wink
hey, it dont have to be pretty as long as you can blow away the hondas
Damon is offline   Reply With Quote
Old 04-25-2001, 06:37 AM   #5
bratmantlz
Member#: 3231
88 626 Turbo
white
Post
glad it works for ya josh and uhh looks like your air filter could use some TLC did you do the install yourself?
Brian aka Bratmantlz
Colorado
bratmantlz is offline   Reply With Quote
Old 04-25-2001, 06:43 AM   #6
Frank
Member#: 3791
Post
Is the kit color coated for an easy install or is there just a hodge-podge of hoses? How much boost are you running 5-7?
Frank is offline   Reply With Quote
Old 04-25-2001, 06:44 AM   #7
yebokmj
Member#: 2213
Brilliant Red
Post
bratmantlz,
I did the install myself see my other pic post for more info. As to the filter, it's looked that way since day one when I oiled it. It a cheap one and I plan on replacing it with one of better quality.
Joshua
Subaru Salesman
Old 04-25-2001, 06:50 AM   #8
yebokmj
Member#: 2213
Brilliant Red
Post
The kit isn't color coated for easy install. It's a kind of feel you way through it project, in the end it's not to bad and Larry made great directions. As to boost I am running 6psi, which is what my 5psi wastegate came set at, and I am still on my stock clutch not to shabby.
Joshua
Subaru Salesman
Old 04-25-2001, 07:11 AM   #9
RyanC
Member#: 2634
1988 5000 CS Quattro
Tornado Red
Post
Joshua, why is your bov mounted so far away from the intake piping? Is that the only place it fit? I'd like to check it out in person sometime
RyanC is offline   Reply With Quote
Old 04-25-2001, 07:21 AM   #10
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Post
Your rich problem could be due to the BOV is venting to atmosphere. That "measured air" should be returned to the intake downstream of the air sensor. The system thinks it has more air than it does.
david2z4 is offline   Reply With Quote
Old 04-25-2001, 07:30 AM   #11
Scoober01
Member#: 3649
2001 Impreza 2.5 RS
Blue Ridge Pearl-Red acc
Post
Not bad man, do you have any idea what your 0-60 looks like now?
Scoober01 is offline   Reply With Quote
Old 04-25-2001, 07:48 AM   #12
yebokmj
Member#: 2213
Brilliant Red
Post
Ryan, The BOV is mounted so far from the intake piping because even with the BOV provided by JC Sports it hit against the hood. So with the larger Greddy one it really will not fit. I hope to have a new pipe fabricated so that it will mount directly to the piping. And you know where I work so feel free to swing by if you in the area or maybe I will see you at the next meet.
As to in running rich because of BOV in to Atmosphere, I know it's not this because I am running an HKS Super AFR for fuel management and it uses the MAF and specificaly adjusts to Blowing off into Atmosphere and learns how the engine runs. Also because the Subaru Scan tool shows that neither of my O2s are reading.
And 0-60 no clue but it's fast enough for me. I would like to go to a strip once to get some speed readings.
Joshua
Subaru Salesman
Pictures of my new engine buildup. Now JDM Version 8/5 hybrid. powerlabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 04-09-2006 10:17 PM
pictures of my engine and parts STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 63 03-28-2003 07:19 PM
('93-'01) Pictures of My Money Pit! yebokmj Impreza Forum 27 04-25-2001 06:31 AM
JC Sports GB Turbo in! Ethan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-13-2001 11:35 PM
JC Sports GB thread, problems! Ethan General Forum Archive 8 04-03-2001 08:20 PM
