Old 07-01-2003, 12:18 AM   #1
tecniks
Member#: 18106
11 STI
Plasma Blue
Default New RS-T in DC-Metro
Last night at 10:30 p.m me and my buddy finished the turbo set-up using factory WRX parts. The total amount of time spent was after work from wednesday to sunday. Pics below.
Ok here is the problem, Driving normally everthing is ok. As soon as you start going for it like over 4thousand RPM it bogs down, Feels stock. The apexi A/F joint on the turbo timer start blinking out of range. (Am I running rich?) Does anybody have some setting for the apexi safc that I could try?
P.S. also using a greddy profec E-O1 boost controler set to 4.5psi and cutout at 5psi.
tecniks is offline   Reply With Quote
Old 07-01-2003, 03:06 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I think you need to explain how your fueling is set up and what type of engine management you have before you can get a straight answer.
Old 07-01-2003, 05:04 AM   #3
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I agree with 8complex.
So how much boost did your boost gauge say you were pushing? Since you said you were using factory wrx parts, if i remember correctly, the wrx turbo wastegate is set to about 8 psi? You can't really set the boost setting on the boost controller lower than the wastegate setting.
cRayZee is offline   Reply With Quote
Old 07-01-2003, 09:09 AM   #4
markus
Member#: 438
2004 STi
White on Gold
Are you running a stock RS exhaust??
We had a local RS-T owner who ran a stock RS exhaust for awhile and he was running into the exact problem you are describing. It went away after he installed a 3" turbo back exhaust.
Just thinking out loud.
markus is offline   Reply With Quote
Old 07-01-2003, 09:43 AM   #5
OKRS25
Member#: 36533
2005 STi
Are you running the stock WRX intake under your RS manifold?!? How did you get it to fit if so?
OKRS25 is offline   Reply With Quote
Old 07-01-2003, 10:45 AM   #6
tecniks
Member#: 18106
11 STI
Plasma Blue
8complex - Still running factory RS fuel pump, lines and injectors. I have been thinking that it might be a fuel cut. *tomorow I will have wrx fuel pump lines and injectors hopefully that will fix the problem. Also, as far as engine management it's the stock RS ECU Apexi SAFC and Greddy ProFec E-01. the car drives great no idling problems just the engine light which I believe is do to me burning the RS o2 sensor in the WRX exhaust manifold.
CrayZee - The boost controller has peaked out all the way to 5.0psi. and spiked to about 5.5
Marcus - Am I running a stock RS exhaust? no Actually its no exhaust. The down pipe goes to the wrx mid pipe and that's it. That will also be fixed tomorow with a Turbo XS rear section.
OKRS25 - No its not a WRX stock intake. I forced a silicone pipe in there. Does anyone know of an intake that would fit on the RS that's not cramped up under the manifold. Any designs that have worked thus far? (I wish I could just relocate the power steering)
Old 07-01-2003, 11:24 AM   #7
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
Cool, the WRX setup is getting more popular. I was able to use a home depot 90 bend on the turbo versus under the intake manifold. I'll be using an actual 90 turbo hose to, but this works fine for now. You'll have to use spacers where the uppipe meets the exhaust manifold to push the turbo back about 1-2", or at least that's what I did, so it doesn't but up against the intake manifold.
http://forums.nasioc.com/forums/show...hreadid=382776
seven881 is offline   Reply With Quote
Old 07-01-2003, 12:11 PM   #8
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
tecniks,
Make a search on JST user name for the all last year and you will find differente S-AFC setup for the differente injection setup i add.
JST is offline   Reply With Quote
Old 07-02-2003, 07:16 PM   #9
tecniks
Member#: 18106
11 STI
Plasma Blue
Thanks JST!
does anyone know if its possible to relocate the power steering like it is in the WRX?
Old 07-02-2003, 07:40 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Of course, just get a pump and a resivour off a WRX and you should be good to go. You may need to get some hardware to connect the lines, too, but I haven't taken a good look at it.
Old 07-02-2003, 08:00 PM   #11
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
Are you running a voltage clamp or does the safc deal with that so you wouldnt need one?
-Marc
boysetsfire is offline   Reply With Quote
Old 07-03-2003, 02:06 AM   #12
rhdude
Member#: 6637
2009 Acura MDX Sport
hey dude welcome to the area, you should post in the mid-A forum and come out to some local meets, meet some of the local RS-T guys like me
rhdude is offline   Reply With Quote
Old 07-03-2003, 07:52 AM   #13
4wheelmotion
Member#: 2044
1999 2.5 rs-T
rally blue/ '96 jetta vr6
good to here your car is running. did you ever get the oil drain figured out?
is your car under boost when problem occurs?
had same problem but was running too rich. but running stock fuel pump? i dont kow??
-robbie
4wheelmotion is offline   Reply With Quote
Old 07-03-2003, 09:27 AM   #14
tecniks
Member#: 18106
11 STI
Plasma Blue
8complex - Yeah it's worth giving a shot! Thanks.
boysetsfire - Not running a voltage clamp. Never heard of the need to use one.
rhdude - I'll most def. come out and check it out.
4wheelmotion - oil drain, no problems there, looking good so far. no, no problems when under boost. About the fuel pump I know, I'm installing a WRX one today. My car has always ran ritch ever since I purchased it, I thaught putting the turbo on would have leaned it out a bit but no, it's still running rich
School me on T-Mobile coverage/reception in DC metro & Baltimore metro areas EGY5 Mid Atlantic Impreza Club -- MAIC 35 07-22-2009 07:25 PM
New RollerHockey Forum for DC metro Area Turbo NV Mid Atlantic Impreza Club -- MAIC 13 01-08-2004 05:33 PM
Good dealerships in DC metro area? KTB Warranty Issues & SOA Problems 2 04-17-2002 10:49 PM
Place to buy gauges in DC metro area John0872 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-13-2001 03:36 PM
('93-'01) $500 over invoice for WRX in DC Metro - low ball? Terp4Ever Impreza Forum 11 04-12-2001 01:34 PM
