Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-01-2003, 10:05 AM   #1
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
Default How to install Focal tweeters in stock location?
A shop used some hot rubber to attach tweeter to the bracket, while I had my door panel off - tweeter got detached because of the sun heat. They say it's the first time they've heard that happen, I say use the screws? What did you guys use? I have a little Foccal pocket that I can put the tweeter into which has a hole in the middle- I was thinking using a small screw and nut combination with the stock tweeter bracket.
Suggestions are welcome.
newsman is offline   Reply With Quote
Old 07-01-2003, 04:58 PM   #2
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
bumpy bump
Old 07-01-2003, 11:16 PM   #3
schmecky
Member#: 21923
04 STI
i've used a screw and nut to hold tweeters in stock location but you have to make sure that you have enough roon using the mounting cup for the tweeter to fit behind the door panel...i also had to cut the srew off after i put the nut on because it was too long....
currently my tweeters are stuck to the metal via their magnets then glued into place....they survived a U.P. winter and a couple warm days this summer with no problems yet!
schmecky is offline   Reply With Quote
Old 07-02-2003, 10:28 AM   #4
elsanto
Member#: 34832
1989 M3
I've used hot glue also just be careful not to get it too hot and definitley dont get any on the moving bits
elsanto is offline   Reply With Quote
Aftermarket tweeters in stock location? francoej Car Audio, Video & Security 15 04-23-2008 06:07 PM
Installing Upgraded speakers in stock locations mzdrati Car Audio, Video & Security 1 11-17-2005 12:21 PM
Tweeters in stock location? Mishmosh Car Audio, Video & Security 3 02-28-2004 01:26 PM
How to install an engine in under 6 hours wac New England Impreza Club Forum -- NESIC 9 04-08-2002 07:20 AM
How to install your deck in a 2002 WRX? [freeman] Car Audio, Video & Security 8 02-28-2002 04:21 AM
