Old 07-01-2003, 01:54 PM   #1
serious
Member#: 22879
Default wrx rear differential/axles in a legacy?
Hi all, asked this question a while back in the transmission forum just to be confused. Some body said that one alxe is longer than the other and some other stuff.
What i would like to know is if the 02 wrx rear differential and axles will bolt right up in a 96 legacy without any issuses. Anyone know?
Thanks
Brent
serious is offline   Reply With Quote
Old 07-01-2003, 03:21 PM   #2
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Don't know, but a good start would be to compare the wheelbase of the 2 cars. If one is wider than the other, chances are they won't match right up.
Speedwagon is offline   Reply With Quote
Old 07-01-2003, 09:03 PM   #3
SubbyRS
Member#: 17193
1991 Legacy RS
I think you mean compare the "track".......wheelbase is the distance between wheel centres on the same side of the car! track refers to the distance between wheels on the same axle....
SubbyRS is offline   Reply With Quote
Old 07-01-2003, 09:13 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Check spline count
Also check if axles are male or female connection to differential
Old 07-01-2003, 10:33 PM   #5
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
There is a thread on the board somewhere that I know I've seen. IIRC, it talks specifically about this issue and even more specifically about axle lengths v-a-v Legacy and the WRX applications and should answer your questions. I'm sure you've already done a search but try "hub legacy shaft wrx" as your criteria and go back at least a year. That may pull it up
Wish I could search but dialup takes too long. Perhaps when I get home. Good luck and re-post what you find out.
Br, Dale
Subietonic is offline   Reply With Quote
2002-2005 WRX Rear Differential R160 out of an 05 WRX Bugeyeballa MAIC Private Classifieds 5 12-04-2008 10:38 PM
NY: 02 WRX rear end, axles, rear brakes and hubs subalou1 Private 'For Sale' Classifieds 10 06-17-2005 01:22 PM
'02 WRX Rear differential and 4 axles, stock seats, and steering wheel cokex Private 'For Sale' Classifieds 4 10-27-2003 10:34 AM
wrx rear differential in a legacy? serious Subaru Conversions 8 06-05-2003 03:52 PM
Subaru rear differential part in SA area? bookbabe1960 Texas Impreza Club Forum -- TXIC 2 09-10-2002 05:33 PM
Message Board Statistics All times are GMT -4. The time now is 08:34 AM.
