Old 07-01-2003, 07:55 PM   #1
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
Question Running Rich
My car has been turboed for about 9 months and 7,000 miles and everything seemed fine except for a minor oil leak on the oil return line. I took it to a shop which my family has been taking all our cars to to have them look at and fix the oil leak and also do a major service. I now realize the major service was a bad idea because god knows what they did.
My car was running fine when i took it to them (minus the burning oil that leaked onto the headers) but now it's running like crap.
I'm running a Ludespeed Stage III with a Link @ 4.5psi.
Some EGT's i recall are:
700* F @ 40 mph
650* F @ 50 mph
525* F @ 70 mph
All temps are in 4th gear btw.
I have a few ideas on what could be causing but I am not so certain.
1) Stock spec spark plugs from the major service (as opposed to what were there when i delivered it - NGK7's i believe)
2) dead 02 sensor (i don't actually know what would happen here)
3) Faulty Link - i have had problems retaining fuel/timing maps with my Link when trying to data log and tune, but never from just driving.
4) combination of all 3
Any help is greatly appreciated.
KillerTHC is offline   Reply With Quote
Old 07-02-2003, 07:39 PM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Bump.
Old 07-03-2003, 01:17 AM   #3
seven881
Member#: 8828
01 BRP 2.2T Hybrid
10 VW Grocery Getter
I'd get a list of what they did to the car, but they could have changed it back to the stock heat range plugs for the car. This seems the most likely culprit. Also, what version of PcLink are you using? I've had problems with the software retaining my changes and causing my car to knock while still NA.
BTW, I'm in Newark, do you ever go to any of the local meets?
seven881 is offline   Reply With Quote
Old 07-03-2003, 01:35 AM   #4
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
I dont know where your egt probe is located but i idle between 600-700 degrees farenheit and would probably be close to 1100-1200 at 70mph in 4th gear.
-Marc
boysetsfire is offline   Reply With Quote
Old 07-03-2003, 03:59 PM   #5
insanesuby
Member#: 23494
2013 WRX
Stock FPR could have craped out on you, happened to me.
insanesuby is offline   Reply With Quote
Running rich- very rich Hondaslayer Normally Aspirated with bolt-on Forced Induction Powertrain 19 04-12-2003 08:11 PM
MBC WRXes running rich? jmott Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-03-2001 02:55 AM
Question on running rich Rubik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-25-2001 04:45 AM
('93-'01) ECU reset causing me to run RICH ? bigbird Impreza Forum 5 04-10-2001 10:53 PM
MY00 Running Rich (C.E. Light) w/ Cobb Intake, Stromung Exhaust Swivel1000 Normally Aspirated Powertrain 8 03-11-2001 03:21 PM
