Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Old 07-01-2003, 10:08 PM   #1
kaos200
Member#: 2692
Question HKS Racing Blow off Valve. Who's got the 411?
I need more "relief" off throttle, the TiAl did the job very well, but I sold it with my gorgeous topmount I had
Now Im using the HKS valve, and its insufficient at times. Im debating installing another one upstream, or replacing it with HKS's Racing valve, which utilizes the same flange.
Problem,.... its made for 3 bar, will 10psi even activate it? Ill be going to 15-20 psi later but for daily driving I need it to let off!
kaos200 is offline   Reply With Quote
Old 07-01-2003, 11:01 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
I run the HKS SSQV, 15psi daily (though 13 right now due to the stupid heat here in AZ) without problem...
I've pushed 17psi no problem as well through that BOV.
kastle is offline   Reply With Quote
Old 07-01-2003, 11:09 PM   #3
kaos200
Member#: 2692
I forget where I read this info but UNDER certain boost pressures (different on every turbo) you cross a zone where the pressure in the system after the turbo can still overcome the spinning compressor wheel. I know I sound like Im on crack, but I understand it in my head.
I just dont want to blow my turbo up...
Old 07-02-2003, 02:34 PM   #4
8Complex
Member#: 922
04 FXT
Red
You mean where the pressure in the system between compressor & TB can backspin the compressor wheel? IIRC, thats from a BOV that doesn't open at low enough pressure differences (between intake tract and in the manifold.
Old 07-02-2003, 07:16 PM   #5
Tats
Member#: 5692
WTF? YES! I am
better than you!
I just switched from my AVO to a HKS SSQ BOV....no complaints at all.....should take care of your car just as good.
tats.
Tats is offline   Reply With Quote
Old 07-10-2003, 01:36 AM   #6
sliver
Member#: 9625
2002 BMW 330i
Steel Blue
or you can always buy the tial back from me
sliver is offline   Reply With Quote
FS: HKS Blow off Valve SSQV & Type 2 Racing Blow off valve nexxus_01 Engine/Power/Exhaust 5 01-12-2009 08:01 AM
FS: HKS SSQV Blow Off Valve, & HKS Type II Racing Blow Off Valve! adamsrs Private 'For Sale' Classifieds 7 09-12-2004 11:41 AM
HKS TYpe II Racing Blow Off Valve! adamsrs Private 'For Sale' Classifieds 12 09-08-2004 02:53 AM
HKS Type II Racing Blow Off Valve adamsrs North West Impreza Club Forum -- NWIC 0 08-24-2004 10:33 PM
FS: HKS SSQV Blow Off Valve, & HKS Type II Racing Blow Off Valve! adamsrs North West Impreza Club Forum -- NWIC 7 08-22-2004 10:48 PM
