Old 07-02-2003, 09:01 AM   #1
HubbieScooby
Member#: 7088
Super Slow
Question want to do some research for my project
hello folks
i have a friend that will be selling me his stock 2002 WRX block for $400...i'm not sure what it will come with....but he said he'll throw in the turbo....the thing is, that i want to try to build a WRX block....things like forged pistons, new rods, crank, etc.....im not sure what i should do with the heads yet....i plan to run everything with an autronic....i have a 2001 RS....so its going to be an engine swap thing....is this worth it?? are there any big benefits to building a 2.0?? i don't want serious race power but just something that i can run maybe 17lbs daily?? the thing about this is that i want to buy the motor so i don't have to pay shipping for the block to hawaii....any inputs on what i'm planning to have to get?? thanx
hugh
HubbieScooby is offline   Reply With Quote
Old 07-02-2003, 10:54 AM   #2
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
honestly, alot of people have done wrx swaps. I would think its the best way to go if you opt not to build up the block. In the end...
If you wire in a wrx ecu, and basically make your car a old school wrx. It will be the more reliable power adder you could do since it is factory turbo.
About the forged internals: I honestly think that would be overkill unless you want 400+hp on race gas. i've seen a wrx run low 12s (i'm talking almost 11s) on 100oct, boltons and a ecu reflash.
i'm not saying don't go forged, because if you do build a 2.0l it might be able to handle a few mistakes (ie bad gas or bad tuneing) better then a cast motor.
non the less, you have alot of options ahead of you. I suggest you read read read about the wrx motor and make sure thats the way you wanna go.
DoctorNick is offline   Reply With Quote
Old 07-02-2003, 06:15 PM   #3
HubbieScooby
Member#: 7088
Super Slow
thanks
the reason i want to build the motor is because i see it as an opportunity since the block is partially disassembled....and knowing that i can boost it higher in a safer sense on those track days ....how much does the parts cost to build the bottem end??
hugh
Need help on swapped gf8, anyone near Savannah want to do some work for compensation? ProjectL South East Region Forum 4 01-07-2010 09:20 AM
I wanted to do something nice for my father this Xmas. I could use your opinion. Drink Off-Topic 23 12-02-2007 09:19 AM
I need to do some research JWX Political Playground 18 10-19-2004 04:08 PM
Want to do something nice for my mom awdity Off-Topic 7 10-02-2004 09:36 PM
For those that wanted to do some ghost hunting Thug New England Impreza Club Forum -- NESIC 1 06-07-2001 06:33 PM
