Old 07-03-2003, 02:06 AM   #1
SC WRX
Member#: 15258
2012 Non-Subaru
Default Luke: What are the weights of 225/40/18 Kumho 712s and Yoko ES100s?
See above.
BTW, congrats on the baby.
SC WRX is offline   Reply With Quote
Old 07-04-2003, 03:44 AM   #2
SC WRX
Member#: 15258
2012 Non-Subaru
Luke?
Old 07-04-2003, 10:35 PM   #3
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
go to each tire on www.tirerack.com and go to specs. the weights are there. and post the answer.
Steppin Razor is offline   Reply With Quote
Old 07-04-2003, 11:39 PM   #4
ripvw
Member#: 27790
Default Hey SC WRX
Luke's probably enjoying the 4th with his wife and new daughter.
Or maybe just catching up on some sleep.
According to Kumho's website, the 225/40x18 size weighs 25.4 lbs. Unfortunately, Yokohama does not list tire weights on its website. From previous research, I can tell you that the ES100 in 225/45x17 size runs 24.4 lbs., and for most brands the 17" and 18" 225's are pretty close in weight.
FWIW, the ES100 beats the 712 in every subjective and objective handling comparison in their test on Tire Rack's website, but the 712's are quieter and ride better. If you haven't already read it, here's the test:
http://www.tirerack.com/tires/tests/...e_you_more.jsp
If it's performance you're after and ride and comfort are not as important, you might consider the Kuhmo MX if you can afford them.
Hope this helps.
Gary
p.s. Steppin Razor - the only weights I've ever seen on the Tire Rack site are maximum load capacities. If there is some hidden feature to click on that gives tire weights, let us know.
ripvw is offline   Reply With Quote
Old 07-05-2003, 09:55 PM   #5
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
well, it turns out that i'm a big idiot and there is no tire weight info on the website. i must have imagined that one.
*jackass*
Old 07-07-2003, 11:44 AM   #6
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
712's = 25.4 lbs
ES100's = 22.9 lbs
NASIOC tire search
fs:ca re050a set of 225/40/18 and 255/40/18 iam_so_slow Wheels/Tires 2 04-09-2010 11:49 AM
NYC FS: 2 bent SSR comps/ 4 225/40/18 Kuhmo 712 DieselClown Wheels/Tires 7 05-11-2007 11:15 AM
Weights Of Alot Of 225/40/18 Tires bellmen167 Tire & Wheel 12 04-28-2004 05:17 PM
FS: 225/40/18 Kumho 712s (2 only) like-new tread AWDconvert Private 'For Sale' Classifieds 4 09-08-2003 12:37 PM
FS: 225/40/18 Kumho 712s (2 only) LOTS of tread AWDconvert Bay Area Impreza Club Forum -- BAIC 5 05-29-2003 08:01 PM
