Old 07-03-2003, 01:44 PM   #1
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Question Trying to install a cold air intake...need help
Today I bought a slightly used CAI from a friend for $5. It's the one Rallitek sells. The problem is that I have no instructions of where the hoses go. If any of you could help I would greatly appreciate it.
Thanks
Eric
gimpless is offline   Reply With Quote
Old 07-03-2003, 02:23 PM   #2
froggert
Member#: 768
OB, volt, 911,
ram 1500, 1098s, m620
not sure how the rallitek one works or looks, but basically all the hoses that go to the intake/air box now have to get connected to the new intake. you may have to use a T-connector.
froggert is offline   Reply With Quote
Old 07-03-2003, 03:36 PM   #3
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Is there any way I could get around using the T connector? The pictures I've seen of it installed shows one, unfortunately.
Old 07-03-2003, 03:54 PM   #4
froggert
Member#: 768
OB, volt, 911,
depends on how many connections the intake has. my weapon-r setup had 4 hoses and 3 openings in the intake. so a T was needed. if you don't have one handy, you may be able to use the one attached to the bottom of the stock airbox.
Old 07-04-2003, 12:02 AM   #5
gimpless
Member#: 3488
1997 Legacy GT
Forest Green
Well, I got it installed. The car idles smoother and has more power in the 3k-4k rpm range. Of course the sound is great as well. I guess everything is working ok.
need to trade my cold air intake ilovemysubie Tri-State Area Private Classifieds 0 10-08-2008 06:04 PM
86 gl 1.8 nonturbo to turbo and cold air intake dblok4eva 'Old School' Subaru Forum 6 10-30-2007 11:02 AM
How to install SPT cold air intake??? Hybridz4eva Southern California Impreza Club Forum -- SCIC 20 05-11-2007 03:01 PM
To Those With Cold Air Intakes..... OrlandoSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 44 09-18-2005 04:20 PM
Trying to install my Blitz FATT (timer), need help SWEETWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2001 02:53 AM
