Old 07-03-2003, 06:40 PM   #1
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Cross post: EGR removal with stock ECU
I want to remove my EGR from my 2.5 engine but I want to know if I just plug the selnoid and leave it if that will be sufficent. Wayne/wac used some stuff to try and avoid the code on his car but his was a 2.2 using a 2.5 ECU and never had the EGR selinoid to just leave in place. Any input before I do this would be apprecited.
Joshua.
yebokmj is online now   Reply With Quote
Old 07-03-2003, 06:43 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
You just need to find out what the resistance of the solenoid valve is when it's normal, and try to wire a resistor in-line to trick the ECU that it's there and ok
Legacy777 is offline   Reply With Quote
Old 07-03-2003, 06:46 PM   #3
yebokmj
Member#: 2213
Brilliant Red
Default Just leave the solenoid?
What if I just leave the solenoid won't that serve the same purpose? It's just a thing that switches on and off correct? I or does it some how know it's not controlling anything if the solenoid isnt connected to the EGR system.
Joshua
Old 07-03-2003, 08:16 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It isn't quite this simple. If you disable the EGR you will eventually get a CEL even if the solenoid remains in place. The ECU checks to see that the EGR is functioning (not just the solenoid, it looks for changes in the 02 sensor when EGR is applied). There won't be an easy way around this without the ability to reprogram the ECU to ignore the EGR.
Also with the EGR removed you may experience some detonation. Since the EGR works to limit NOx emissions by lowering combustion temperatures, it also reduces the tendency for the engine to detonate. When the engine is designed and the ECU maps written, the presence of the EGR is taken into account.
Old 07-04-2003, 08:00 PM   #5
Legacy777
Member#: 4800
Just curious, how does EGR valve reduce NOx & detonation. NOx forms in high temps, high MEP, etc. Does reducing the amount of oxygen by inducing already burned gasses reduce the overall combustion temps?
Old 07-04-2003, 08:04 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes, that's the basic function of EGR. Its primary purpose is to reduce NOx by lowering the temp, and detonation is reduced as a byproduct of those lower temps.
after removing utec,stock ecu questions. Woofy Engine Management & Tuning 1 05-21-2010 04:54 PM
Cobb Stage 2 ECU for trade with stock ECU + $200 chohakai Private 'For Sale' Classifieds 1 11-13-2004 03:40 AM
Who has removed EGR, with stock ECU? yebokmj Normally Aspirated with bolt-on Forced Induction Powertrain 0 07-03-2003 06:18 PM
just how bad does car run with stock ecu and sti injectors suprasingle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-24-2002 01:54 PM
What psi/boost with stock ecu = CEL? SGOSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-17-2002 09:39 PM
