Old 07-01-2003, 02:28 PM   #1
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Default Throttle Blip
Recently when I was getting my clutch installed we ran into a few problems and eventually had to put an ECU in from another car (same year and body style) but ever since then I have had a throttle blip at 3400 RPM when in at WOT in every gear. I was wondering if anyone else has had a similar problem, or if anyone knew how to fix this. The only thing I can think of to fix this is to reset the ECU but I havent had the time to do this yet.
JewPac42 is offline   Reply With Quote
Old 07-02-2003, 11:25 AM   #2
JewPac42
Member#: 23260
Patr ick Willis
Anyone?
Old 07-02-2003, 12:23 PM   #3
Monas
Member#: 31418
1999 2.5RS
what do you mean by a throttle blip? is it a hesitation, missfire, or afterburn type problem? also what other mods do you have on your car?
how long ago where the plugs changed?
Monas
Monas is offline   Reply With Quote
Old 07-02-2003, 01:32 PM   #4
JewPac42
Member#: 23260
Patr ick Willis
Monas
It is a slight hesitation. As far as power mods I have cobb inatke and tanabe hyper medallion exhaust. I changed the plugs about 2 weeks ago, maybe less. The problem was there before, and it is still there.
Old 07-03-2003, 12:10 AM   #5
ImprezzvRS
Member#: 24171
2000 Impreza RS
"THE" Blue
I think i know what you are talking about, but i dont really see how it matters too much. it might just be a slight hesitation but nothing really serious. Have you tried the Grounding Mod at ScoobyMods.com ? It might be an electrical blip I dont know, but since I have dont this mod I haven't had too many probs. Cheers
Rob
ImprezzvRS is offline   Reply With Quote
Old 07-03-2003, 12:44 AM   #6
Blindeye_03
Member#: 4418
2016 Focus ST
maybe your ecu needs to be flashed?
-justin
Blindeye_03 is offline   Reply With Quote
Old 07-04-2003, 05:52 PM   #7
JewPac42
Member#: 23260
Patr ick Willis
-justin
Do you mean reset?
Old 07-04-2003, 06:26 PM   #8
Ken
Member#: 34
2005 WRX STi
World Rally Blue
Sounds like the regular 3.x-4krpm flat spot in the RS. Or check to see if there is a recall on the ECU's. There was one for 99's and someone I know got one for 01's as far as I know.
Ken is offline   Reply With Quote
Old 07-04-2003, 07:47 PM   #9
JewPac42
Member#: 23260
Patr ick Willis
Its not a flat spot. It wasnt there before the ECU from the other MY00 car went in. It is almost like hitting a rev limiter. A hesitation at 3400 RPM then it goes back to normal.
Throttle Blip After Coming off the Throttle? Shaved Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 04-05-2005 07:44 PM
STi automatic throttle blip? markpaco STi Forum Archive 23 09-10-2003 07:50 AM
throttle blip = ??? austenf740 Transmission (AT/MT) & Driveline 14 11-03-2002 06:43 PM
slow rev response to throttle blip hedgehog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-12-2002 08:34 AM
throttle blip when changing gears Joraq Warranty Issues & SOA Problems 8 03-22-2002 08:15 PM
