Old 07-03-2003, 07:17 PM   #1
Santo Domingo 2.5 RS
Member#: 5354
Silverthorn Metallic
Default Ideal Vacum Lines
HI, i am ready to begin installing everything, i am not really sure yet, of where should I tap for my vacum lines for everything I need to install. And is there any benefit for hooking them up on a certain way?
These are the thing i need to get boost readings for:
J&S Safeguard
Boost Gauge
Turbo Timer
FMU
Boost Controller(EBC)
BOV
Santo Domingo 2.5 RS is offline   Reply With Quote
Old 07-03-2003, 09:16 PM   #2
Avenger
Member#: 1234
There are two vacuum fittings on the passenger rear of the intake mainfold that you can use for vacuum source.
Avenger is offline   Reply With Quote
Old 07-04-2003, 01:40 AM   #3
Member#: 5354
Yes, Ive seen them, but they are both on cyllinder 3, I dont like the idea of hooking everything to an intake runner. Maybe having so many Tees there might not give me the best readings.
Are there any other places where I can tap to get boost readings?
Old 07-04-2003, 02:26 AM   #4
Avenger
Member#: 1234
The only other place I can think of is where the map sensor sits. But then you'll have to take it off put a pipe in there and tee the map into a vacuum line.
Old 07-04-2003, 03:47 AM   #5
8Complex
Member#: 922
04 FXT
Red
The most preferable location is in the center plenum of the manifold, obviously. I don't think I have anything on my #3 runner because of all the errors in the readings... my Haltech used to vary between 3.2-5.1psi when I was only boosting 4.5 solid because of the valves opening and closing. FPR's also vary pretty quickly on there as well.
I actually have an external MAP sensor and intake air temp. sensor, so I made a plate to replace my MAP sensor that has several other vacuum line inputs, and I have a double T on the other port near the TB.
Old 07-04-2003, 10:11 AM   #6
Member#: 5354
so if I dont make a plate for the map sensor. The only place is the intake runner? Arent there any other places where i can just cut the lines and tee on them?
Old 07-04-2003, 09:00 PM   #7
Avenger
Member#: 1234
There are no other places. Unless you drill the mainfold.
Old 07-04-2003, 09:38 PM   #8
Member#: 5354
Can you all please post where have you tapped the lines for each different thing (Fmu, Bov,etc..)????
I think You might need better readings for some things, and for some other you might not. What have you guys done?
Old 07-05-2003, 03:17 AM   #9
8Complex
Member#: 922
04 FXT
Red
http://forums.nasioc.com/forums/show...ghlight=vacuum
I changed mine since I posted this, obviously.
Old 07-05-2003, 10:26 AM   #10
Joncas
Member#: 5349
8 - what were all those 1 way check valves for? (atleast they looked like little check valves - filters?)
Joncas is offline   Reply With Quote
Old 07-05-2003, 12:57 PM   #11
8Complex
Member#: 922
04 FXT
Red
Joncas - Where are you looking? I don't think I have a single check valve in my system in my car...
Old 07-05-2003, 04:28 PM   #12
Joncas
Member#: 5349
My bad.... in your linked post is a picture of Revision's car.
Stock boost controler vacume line routing SupraTT&WRX Factory 2.0L Turbo Powertrain 2 03-08-2004 11:20 AM
Vacum Line, More Boost? MarcsRX Factory 2.0L Turbo Powertrain 10 05-05-2003 06:28 PM
('93-'01) 4x4 vacume lines Big-C Impreza Forum 0 10-23-2002 06:18 PM
Justy 4x4 vacume lines? Big-C Newbies & FAQs 0 10-22-2002 02:23 PM
Changed vacume lines, affected boost? Ethan Normally Aspirated with bolt-on Forced Induction Powertrain 9 01-11-2002 01:45 AM
Message Board Statistics All times are GMT -4. The time now is 12:25 AM.
