Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 07-03-2003, 10:24 PM   #1
rhdude
Member#: 6637
2009 Acura MDX Sport
Default pulled 2 CEL's codes... need some help.
just pulled these two codes:
P0102 = MAF signal low input
P0325 = Knock Sensor Malfunction
Car idles ok, a little rough... but stumbles and bogs when you press the gas and try to move the car...
Any ideas? I just put in a fresh MAF and it did'nt make it any better...
could the knock sensor be bad, causing the ECU to pull timing, making the car bog?
thanks,
Brian
EDIT: forgot to add, the intake had fallen off, causing the maf not to read... thus sending the bad signal? so its more of a knock sensor problem?
rhdude is offline   Reply With Quote
Old 07-04-2003, 01:28 AM   #2
Mancini
Member#: 20726
The trouble shooting diagnostics for P0325 say it'll cause "poor driving performance" and basically is a result of sensor or electronics failure. Check and make sure the knock sensor is still connected and that the connecting bolt is tightened. There are a few other checks involving checking the resistance between the ECU and the sensor to see what exactly needs replaced. If you want I can email the scanned diag pages for that code.
Hope that helps,
Brian
Mancini is offline   Reply With Quote
Old 07-04-2003, 02:27 AM   #3
Avenger
Member#: 1234
You said the intake fell off. See if there any place that is not clamp tight. I'm thinking there is a leak somewhere after the MAF sensor.
When you fix the MAF problem you'll probably fix the knock code.
Avenger is offline   Reply With Quote
Old 07-04-2003, 03:24 AM   #4
rhdude
Member#: 6637
The MAF problem was solved...
The wiring conector to the knock senser was loose before, and I fixed it, I geuss it worked itself loose again...
Brian- please send those pages to rhdude@hotmail.com Thanks man!
Old 07-04-2003, 11:25 AM   #5
Mancini
Member#: 20726
Emailed. Let us know what was wrong.
Old 07-04-2003, 01:12 PM   #6
Unsung Boxer
Member#: 37196
I had the same code from my knock sensor. I was about to buy a new one for almost 100 bucks from Subaru... then I went to unscrew it to bring it in and it was loose as hell. I believe the ECU retards the timing like hell to ensure that there is no predet when the knock sensor isnt working.. this is why the car will hardly run. From what i discovered... if you get the Knock Sensor code.. it is either broken or loose, otherwise ull never get it.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 07-04-2003, 03:25 PM   #7
rhdude
Member#: 6637
Cool, thanks for the info! I'll go check the sensor and the wiring in a little bit and let you know what I find...
Old 07-05-2003, 02:11 AM   #8
rhdude
Member#: 6637
yup, loose wiring connector... car runs great now.. thanks for all the help guys!
Old 07-05-2003, 11:28 AM   #9
Unsung Boxer
Member#: 37196
I have heard this problem so much. When I put my motor together I was so anal about Torque Specs because I wanted everything to work like factory when I got done. I think i even used a torque wrench on the Knock sensor.. no surprised it came loose now that I think about it. Subaru shoulda put some sort of lock washer on that one. Oh well, easy fix
For now on, Im just gonna use German Torque Specs...
GŁtentight
Going Stage 2 Soon Questions. Need Some Help! DJS_02_WRX Newbies & FAQs 7 09-19-2009 12:06 PM
ARG! i hate CEL's / sensors... need some help please. ScubyMedic Service & Maintenance 2 02-26-2007 11:00 PM
stock wrx turbo on 2.5 rs? need some help Rtony103 Subaru Conversions 3 10-18-2006 02:32 AM
i need some help with a few cel's!!! Berts_Wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-13-2006 01:10 PM
1.8 to STi 2.0 swap... need some help. wagman01 General Forum Archive 5 02-21-2001 09:57 PM
