Old 07-03-2003, 10:34 PM   #1
Jay04WRX
Member#: 34075
2009 CTS-V
Default 04 WRX w/ TXS stage 2 dyno results
I personally was not happy with these results with 202 AWD HP and about 252 crank HP. This is with a stage 2 TXS kit. Still beats stock but not living up to what I thought....
http://www.cardomain.com/member_page...69_33_full.jpg
Jay
Jay04WRX is offline   Reply With Quote
Old 07-04-2003, 12:25 AM   #2
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Default Re: 04 WRX w/ TXS stage 2 dyno results
Jay
Something is wrong. I made 228/235 with the same setup (only uppipe cat) on a mustang dyno.
What boost were you running? What was your timing like past 6K? Something is off.
TypeC is offline   Reply With Quote
Old 07-05-2003, 11:35 AM   #3
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Jay,
Either your ignition timing is way off, you have a lemon, or you're not using our exhaust system. Your boost was 14.99 psi and the AFR was 10.7 so unless your timing was extremely low you should be making good power. There are also some dips in the curve which could indicate the UTEC was pulling timing.
Fill in the blanks.
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 07-06-2003, 08:39 PM   #4
Jay04WRX
Member#: 34075
2009 CTS-V
Originally posted by motoxphil
Jay,
Fill in the blanks.
Phil
TurboXS
Maybe a lemon UTEC, i dont know what was wrong but I am going back very soon to have Danny tune and Dyno it again because something was DEF off
two things come to mind about my #'s vs. other dyno numbers that I have seen. I believe it was the heat, seeing those other numbers I will be coming back to the shop anyways in a week or 2 to get another 6 pulls and dyno'ing results. hopefully this time the weather wont be as hot.
Today the car knocked(detinating*) a few times even after then tuned it and set the boost to 15.5PSI....
Stage 2 Dyno Results.... wirolla Proven Power Bragging 15 08-07-2006 12:33 AM
cobb stage 2 dyno results madkayaker Engine Management & Tuning 9 02-09-2005 09:49 PM
04 WRX w/ TXS stage 2 dyno results Jay04WRX New England Impreza Club Forum -- NESIC 27 07-07-2003 02:30 PM
TurboXS Stage 2 dyno results... DP WRX Mid Atlantic Impreza Club -- MAIC 2 05-24-2003 03:33 PM
Ecutek Stage 2 Dyno Results WRX-Hellfire Proven Power Bragging 5 01-16-2003 11:43 AM
