Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 01-08-2001, 01:44 PM   #1
Rallyrcr
Member#: 3407
1995 WRX Rally Car
Caribbean Green Met
Question Koni's for SVX .......too stiff?????
Hey guys i have a set of Koni's for my SVX those who have them are they too hard and annoying for long trips and daily driving?
I heard the softest of the 3 settings is ok but before making the mod i want to be sure these things are even worth it.
I don't need a race car for the streets (like poser honda ricers) i get all the speed i need from actually racing my other subaru, but i do enjoy a nice spirited drive in the country road from time to time. But i don't want to bounce down the road like tigger the tiger...... M 3's and 911's don't bounce and they handle quite well so is there a need to change out the shocks??
Rallyrcr is offline
Old 01-08-2001, 02:24 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
are they a full coil over kit??
or just the struts??
if you keep them on the softest setting.. you should be ok... KONI's by nature are a stiff set up... so definately go with the softest setting...
j. www.subiegal.com
Subie Gal is offline
Old 01-08-2001, 02:33 PM   #3
Rallyrcr
Member#: 3407
1995 WRX Rally Car
Caribbean Green Met
Post
no
the old struts have to have the spring perches stolen and the whole thing needs to be rebuilt with the new shock inserts.
nothing is off the shelf on these cars due to the expense of the parts.
thanks for the attempt
have you owned or rode in an svx with the mod done? that is the info i'm after.
no need to have teeth jarred loose going to the store or on a 3hr drive. if i wanted a ride like that i would go and buy a pickup truck and lift it. if i did i could have saved thousands of dollars too and not bought a $30k sport GT coupe
Rallyrcr is offline
Old 01-08-2001, 02:37 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
nope sorry.. never rode in an svx with koni's...
just a Legacy GT.. guess that's not the same and u are on your own...
sorry... just trying to help.
have fun.
Old 01-08-2001, 04:17 PM   #5
johnfelstead
Member#: 856
2005 JDM STi
Post
Guys, the Koni's are different to most adjustable dampers on the market.
Unlike Competition dampers like DMS for example, Koni uses the 3 click adjustment to compensate for wear. Lots of people crank them up to hard at new, this is not how Konis are designed to work.
You should start on softest settings then as the shock wears increase it by one click.
This info is for the Road spec Konis and not the full race shocks that Koni is world famous for, they are proper adjustable bump/rebound in the conventional sense.
Hope this is usefull.
johnfelstead is offline
Old 01-12-2001, 11:19 AM   #6
Rallyrcr
Member#: 3407
1995 WRX Rally Car
Caribbean Green Met
Post
cmon no one with an svx has these on their car??
thanks for the help thus far
Rallyrcr is offline
Old 01-12-2001, 11:42 AM   #7
1994subarusvx
Member#: 3358
Post
i have heard that the koni's are too stiff so i am not even going to deal with them, plus they are just too expensive. i am going to buy the ground control springs. i want to lower the car 2 inches in the front and 1 inch in the back. i think it will make my car and the 17" Enkei rs6's i just recently put on it look great. am i the only one that thinks that the svx rides too high in the front??
1994subarusvx is offline
Old 01-12-2001, 02:09 PM   #8
1994subarusvx
Member#: 3358
Post
i dont think the svx scrapes because the front end is too low. i think it scrapes because it is just long. for where and how i drive two inches is nothing. plus i think the stiffer springs will accomplish what i think the koni's fail to do, which is stiffen the ride a little without making you feel like you are in a f-1 racing car. i want to stop the body from swaying so much but i dont want to be rattled out of my skull...: )
Old 01-13-2001, 12:41 AM   #9
Rallyrcr
Member#: 3407
1995 WRX Rally Car
Caribbean Green Met
Post
i though it was jjuuussstttt right
i tend to scrape at times going into some driveways and i'm sick and tired of the road dropping away (sunken grade) and the stock shocks not up to keeping the tow hooks in front off the road...sscraakkkkkk
i'm also a rally driver and sometimes forget the street car is not a race car.......
also re height, i cant get a floor jack under it to raise the car and i cant just have a look under it or change the oil with out raising the car.
so i never thought the car was too high my .0003 of a cent's worth
Rallyrcr is offline
Old 01-13-2001, 11:42 PM   #10
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post
I can make a general comment about Konis, having had a set on a Dodge Intrepid with Eibachs. Fantastic! Not at all harsh even on poor Chicago roads, and made the car into a handling beast. Obviously, hardness is a subjective thing, but none of my passengers commented on it, ever, which was a good sign.
But because they are cartridges, better have a line on a good installer.
Kevin
gtguy is offline
HTML code is On
Swaybars: How stiff is too stiff? deft Brakes, Steering & Suspension 16 05-26-2004 09:57 AM
Do you think the 04 STI's ride is too stiff? Foghat STI Brakes, Steering & Suspension 43 10-25-2003 01:43 AM
Anyone else think the STI Spec C suspension too stiff? Any suggestions? carlm Brakes, Steering & Suspension 10 06-01-2003 01:52 PM
Whats a good aftermarket clutch that isn't too stiff on the clutch pedal edkwon Transmission (AT/MT) & Driveline 6 09-09-2002 11:15 PM
M2/DMS 40mm... too stiff for the street? WRX Power Brakes, Steering & Suspension 11 03-14-2002 11:36 AM
