Old 07-05-2003, 11:44 AM   #1
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Default What would upgrading my springs and retainers only do for me?
I am thinking of just upgrading my springs and retainers on my stock heads would it allow a higher redline of 7k-8k? How much work is it really pop off the valve covers and slap them on (over simplified?). I know I will need them torqued down. If I did put better cams how much more work is that? Is there any insructions out there?
Thanks
Ralph
cpu77 is offline   Reply With Quote
Old 07-05-2003, 11:55 AM   #2
bryan2.5rs
Member#: 6807
2005 STi
Crystal Gray Met.
you have to pull the cylinder head off to compress the springs
bryan2.5rs is offline   Reply With Quote
Old 07-06-2003, 12:02 AM   #3
kaos200
Member#: 2692
Default Re: What would upgrading my springs and retainers only do for me?
Thanks
Ralph
stock cam profile is worthless at that rpm
kaos200 is offline   Reply With Quote
Old 07-06-2003, 09:19 AM   #4
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
Anyone have instructions for swapping the heads and cams?
What can I do for $1k cams, spings, valves, retainers? If I do not have the heads ported and polished will it make that big of a diffence?
Old 07-06-2003, 01:05 PM   #5
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Give Trey a call. He's one of the best when it comes to head/cam combinations.
www.cobbtuning.com
Fitz
Fitz is offline   Reply With Quote
Old 07-06-2003, 01:50 PM   #6
cpu77
Member#: 12631
2000 RS-T 9psi!
BRP
I know I am just trying to save the money. Cobbtuning at 3k is a little too much for me.
Old 07-06-2003, 01:53 PM   #7
boysetsfire
Member#: 6218
2001 2.5rs-t
silverthorn metallic
I dont know how extensive the rest of your build up is but if you are still running stock rods id be a little scared to spin them at 8,000 rpm especially at above stock horsepower.
-Marc
boysetsfire is offline   Reply With Quote
Old 07-06-2003, 02:05 PM   #8
Solomon
Member#: 36587
2000 Legacy GT (BE)
I would do this at the same time, or at lest do this first
http://www.pdmturbos.com/Index11.html
You are better off to build up internals before increasing the rpm's, not to mention the heat. Just a cam would help, but I have been looking for some time on these parts and have decided it is better to build up those internals first. Do the springs, and retainers with rockers when you do a port and polish if you want to go that far. Do everything in stages. Pistons, rods, rings, etc…is a good spot to start for a N/A-Then if you go turbo, no worries with something going bad if you have a good ECU onboard. Everything else will be much easier and less risk of something going grenade inside with those in place. Just another note, with that higher RPM you still might be passing your peak HP range too.
Solomon is offline   Reply With Quote
WTB: Upgraded SOHC EJ25 valve springs and retainers rs-jeff Private 'Wanted' Classifieds 0 08-29-2008 09:30 AM
What would a 50/50 meth/water mix do for my traps? karl750 Water/Methanol Injection, Nitrous & Intercooler Cooling 11 10-23-2007 03:58 PM
Just got in my springs and got KYB AGX's for 380! HolyCrikey Brakes, Steering & Suspension 10 01-17-2005 01:52 AM
I would give my wang, and all four limbs, for.... eurojax Off-Topic 50 12-10-2004 04:28 PM
Upgrading Cams, do I need new springs and retainers? obyone Normally Aspirated Powertrain 7 03-25-2004 11:06 PM
