Old 07-06-2003, 03:33 AM   #1
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Axis 2.35L,6-speed,ect
Default I Have A Question About Morrete Headlights For 02/03 WRX? Morrette owners help me out
Im gonna be buying a set of Morretes off a freind and there is a little proublem. It comes with plug and play harnesses and all.
Ok Heres the dillema-- When the regular projector lights are on it works fine both light up. But when he turns the high beams on the driver side regular driving lights come on with the high beams but on the passenger side only the high beam light comes on but not the regular driving light with it.
Does anyone know why this happens. Which side is the side thats the right one. The one with both driving and high beams on or just the high beams side. Let me know if you know any way to fix that so when i turn my high beams on that it lights up properly on both sides. Thanks a lot, Eric
( If you want you can e-mail me at [email protected] )
BLUETURBOWRX is offline   Reply With Quote
Old 07-06-2003, 06:15 AM   #2
SilveRex
Member#: 12461
When my high beams are on I get both lights on each side to light up.
Dunno a fix, maybe he has the wire harness hooked up wrong
SilveRex is offline   Reply With Quote
Old 07-06-2003, 08:14 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Both lights should be on with the high beams. Make sure that the two wires that go from the driver side light assembly to the passenger side are connected, one of those wires is the power for the high beams (which apparently is working) and the other is a ground necessary for the relays which keep the low beam on with the high. Also make sure the ground wire is connected from the driver side light to the battery negative.
Old 07-06-2003, 11:42 AM   #4
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Thanks for the help, Is there any other suggestions on what it can be? Also I dont think he has instructions does anyone have step by step instructions that they can give so i can install them propperly? thanks,eric
Old 07-06-2003, 11:47 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That's all I can think of, the things I mentioned will cause your problem if not connected properly. The only other thing I can suggest if those check out, is to look carefully inside the light assemblies on both sides and make sure all the wiring is plugged in especially the relays.
Old 07-08-2003, 10:57 PM   #6
BLUETURBOWRX
Member#: 22968
EVO WRX Parted Out-
Thumbs up
Anyone else have any suggestions???? thanks,eric
question about headlights for 02-03 wrx rexman2002 Electrical & Lighting 6 08-18-2007 08:27 PM
FS: PSM Morrettes Headlight for 02-03 wrx jumpman86 Tri-State Area Private Classifieds 10 05-03-2007 12:21 PM
Question about Aftermarket headlights for 02/03 zer0_thirteen Newbies & FAQs 9 11-30-2004 12:40 AM
FS: EDM STi headlight for 02/03 WRX + STi CF side binker twlai New England Impreza Club Forum -- NESIC 17 04-07-2004 09:35 PM
OEM Headlight for 02,03 wrx Squid Private 'Wanted' Classifieds 5 02-24-2004 11:44 AM
