Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 07-06-2003, 02:04 PM   #1
ITWRX4ME
Member#: 24472
2001 Miata
Angry UTEC Stopped Working - Anyone Had This Problem?
Friday night, I went to start my car and, when I turned the key to the ON position(not the accessory position), the CEL started flashing continuously. When I tried to start it, the engine would turn over but would not start.
To make a long story short, I removed the UTEC and the problem went away. Reconnected the UTEC and the problem came back. Removed the UTEC and the problem went away.
Is it fair to say that conclusively proves that the UTEC is causing the problem?
Anyone else seen this?
ITWRX4ME is offline   Reply With Quote
Old 07-06-2003, 02:09 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
I bet calling TurboXS is the first thing you'll be doing tomorrow morning. That's a bummer, man, I haven't heard of that happening before.
Zola is offline   Reply With Quote
Old 07-06-2003, 02:51 PM   #3
nmyeti
Member#: 4980
Check your switch position, both on the back of the UTEC and the remote switch if you have one, because it sounds like you have enabled security mode.
If not, give us a call on Monday and we'll walk you though a few things. If we canít solve your problem we'll work with either you or your dealer (assuming they are authorized to sell the UTEC) to get you a new unit.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 07-07-2003, 09:34 AM   #4
ITWRX4ME
Member#: 24472
2001 Miata
Ding, ding, ding, ding, ding!
Nathan wins! I have the remote switch and it was indeed set to 7. I completely forgot about the security mode. I was under the dash Friday night, running a wire for my trailer. I must have pressed the button inadvertantly.
When I got in the car this morning to go to work, it dawned on me that the UTEC had the security mode and maybe I should check the switch. :embarassed: I never even think about that switch!
Yeah, it was the UTEC alright. Just doing what it was told to do.
Nathan, when I reinstall the UTEC, do I need to make sure the switch is at 7 when I connect it? I just want to be sure that there isn't a counter in the UTEC that can get out of phase with the switch.
Thanks,
Jim
Old 07-07-2003, 10:04 AM   #5
nmyeti
Member#: 4980
Thanks,
Jim
Jim,
It can be set to anything you want it to... of course if you want the car to start, Iíd set it to something other than 7.
Old 07-07-2003, 11:48 AM   #6
ITWRX4ME
Member#: 24472
2001 Miata
Thanks, Nathan. I just wanted to be sure that, when I reconnected the switch, the UTEC would use whatever the switch is set to, rather than the last setting it saw when I disconnected it. Does that make sense?
Old 07-07-2003, 01:21 PM   #7
TexRex2002
Member#: 36303
06 Evo IX
if you can hookup a laptop, go into "Dashboard," and you'll be able to see what position the switch is set to. That should make you feel comfortable.
TexRex2002 is offline   Reply With Quote
Old 07-07-2003, 02:04 PM   #8
ITWRX4ME
Member#: 24472
2001 Miata
yep
Gas door won't open... anyone had this problem? drdome99 Warranty Issues & SOA Problems 31 04-27-2011 06:20 PM
has anyone had this problem before? superblkwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-22-2007 12:30 PM
anyone had this problem?? FreeriderSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 09-18-2006 02:33 AM
anyone had this problem? Sharmin7 Normally Aspirated Powertrain 2 05-09-2005 04:14 PM
has anyone had this problem? 42202sub Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-03-2002 09:26 PM
