Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 07-06-2003, 02:31 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default WRX engine swap radiator questions.
Hi, I was wondering if the radiator has to be swapped in doing a WRX engine swap? I was wondering if the stock WRX one will fit into an older GC8 or if it has to be modified?
Please help, Micah
Old 07-07-2003, 12:39 AM   #2
fellfrosch7
Member#: 2389
'98 Impreza L Wagon
'90 Talon TSi AWD
I'm pretty sure you have to use the WRX radiator to use the WRX radiator hoses. You can make an RS/L radiator fit, but the hoses will be different - I think they attach to the engine in different places on the WRX and the older cars.
fellfrosch7 is offline   Reply With Quote
Old 07-07-2003, 11:11 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
hi, I was really wondering as to will it bolt onto the older cars? Does it have the mounts located in the same place?
I knew that the hoses came out in different places but am, wondering about how it will mount.
Thanks, Micah
Old 07-07-2003, 11:52 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the hoses attach to the engien at the same point ... but the radiator is diffent. you can use your L/RS radiator
and plumb it like this (i-speed's work)
or
or mine .. i moved the lines under the radiator hose it looks much nicer now
Old 07-07-2003, 12:08 PM   #5
phong
Member#: 10884
2002 WRX Wagon
PM yamarocket630 or search for the thread in the midwest forum that details his swap (I would but I have to run). I am pretty sure he did it in his conversion.
Dan
phong is offline   Reply With Quote
Old 07-07-2003, 03:18 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The waterpump is different on the turbo models. It has a forward mount for the thermostat instead of a vertical mount. However, I believe you can still use your stock radiator hose. It might be slightly pinched unless you buy a spring to prevent that.
The mounting points for the WRX radiator are different so unless you can do some custom fabrication, it won't mount in the GC/GF chassis.
-Jon
Old 07-07-2003, 04:42 PM   #7
phong
Member#: 10884
2002 WRX Wagon
Try this, this may or may not help?
http://forums.nasioc.com/forums/show...k&pagenumber=3
Old 07-07-2003, 07:21 PM   #8
Cacophony
Member#: 213
2004 Mazda RX-8
I have an STi V engine in my RS, and I run a stock WRX radiator. Stock RS rad would not work, and it is not as good as the WRX unit. Swap it!
Cacophony is offline   Reply With Quote
Old 07-07-2003, 09:40 PM   #9
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
What was required to install the WRX radiator?
-Jon
Old 07-08-2003, 04:02 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
thanks guys, this has been a big help. I don't need to swap the radiator now but I do plan on getting a GC8 WRX alum racing one when I get some more money. Thanks for the tips and the photos really helped.
Thanks, Micah
Old 07-08-2003, 05:49 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
oh there is one more important fact that i forgot
you need to remove the spring from the lower radiator cap this will allow coolant to flow in to the upper tank...
is this a stupid question on wrx engine swap? newbiescooby2.5rs Newbies & FAQs 1 08-16-2005 03:06 PM
WRX engine swap drivetrain question Soobie22 Subaru Conversions 6 03-27-2005 09:03 PM
WRX Engine Swap Question rs2.5-3.0 Subaru Conversions 3 02-23-2005 07:10 AM
WRX Engine Swap Question rs2.5-3.0 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-22-2005 11:01 PM
WRX to RS engine swap exhaust questions racer25rs Normally Aspirated with bolt-on Forced Induction Powertrain 1 05-20-2002 02:04 PM
