Go Back   NASIOC > NASIOC Archives > NASIOC Archives > SVX Forum Archive
Old 03-17-2001, 09:22 PM   #1
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post rear wheel drive
Yup, that's what Robert and KevinL are cooking. Or I should say cooked. They converted KevinL's SVX into rear wheel drive. I got a ride in it tonight and lets just say, it's alot more fun.
Hearing the wheels spining is really cool.
kastle is offline
Old 03-18-2001, 09:51 AM   #2
KEVINL
Member#: 3525
2004 Duramax W/500HP
And Want another STi
Post
I can't wait to drive it I'm sure its gobs of fun
KEVINL is offline
Old 03-18-2001, 11:13 AM   #3
CRZ_MSL
Member#: 1610
Post
Why?
Without AWD an SVX is a Toyota Soarer/CLK320/BMW 630/Infiniti M30 without the aftermarket support.
To dyno test perchance?
CRZ_MSL is offline
Old 03-18-2001, 01:32 PM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
Maybe cause it's fun and different...???...
kastle is offline
Old 03-18-2001, 08:23 PM   #5
KEVINL
Member#: 3525
Post
Ok here's the story My SVX used to be Aaron B's and the front Diff. ran out of gear oil which melted the speedometer gears and damaged the ring and pinion of the front diff. So i just replaced the speedo gears hoping it would last a while flash forward 2 months After getting the turbo install done I noticed under even the slightest load the diff would make noise showing it's wear. I was just messing around with Robert saying I wonder what A Rear wheel drive SVX would be like. So he had the idea of doing this project on my car which would. make the front diff problem no longer a issue. Also it will make trying different gear Ratios a cinch
KEVINL is offline
Old 03-18-2001, 08:28 PM   #6
KEVINL
Member#: 3525
Post
oh we removed the Clutches which lock together to engage AWD and welded both shafts together to make it one solid shaft and we pulled the front CV's still leaving the outer cup to hold the bearings in. I would not recommend this conversion to a novice it was quite a task
KEVINL is offline
HTML code is On
Rear wheel drive/rear drive bias AWD? jensht Transmission (AT/MT) & Driveline 0 02-17-2006 06:13 PM
How to switch Auto to rear wheel drive? ImprezedRS Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-23-2001 09:55 PM
Rear Wheel drive fun KEVINL South West Impreza Club Forum -- SWIC 5 05-24-2001 10:03 AM
MY99 How Hard to convert to rear wheel drive???? Xscreamer Normally Aspirated Powertrain 12 05-24-2001 04:28 AM
rear wheel drive mod and front axles ins8ibl New England Impreza Club Forum -- NESIC 8 05-08-2001 12:52 AM
