#1 |
Member#: 12535
NWIC
Vehicle:vf39 93 Legacy Wagon 92 Legacy Rally EG33'd |
Does anybody know the differences between the 96 EJ25 DOHC and 97 EJ25 DOHC?
My 96 makes 155 TQ @2800 and 155 HP @5600. It also requires premium fuel. The 97+ EJ25's make 11 and 10 more respectivly. 96 EJ25 - timing 15B bore 3.92 stroke 3.11 CR 9.7 to 1 97 DOHC timing ? bore ? stroke? CR ? What vital systems are different? Any added sensors? I want to know how to get the extra power into my 96. Could it be as easy as an ecu swap? I just dont understand how the newer EJ25 makes more power and requires less octane than the 96 even with the higher CR. Tuning obviously but how do I benefit?
#2 |
Member#: 6637
Vehicle:2009 Acura MDX Sport |
the '98 RS has a lower compression than 10:1... I think its like 9.5:1...
but, in general, on N/A cars, higher compression means more HP... |
#3 |
Member#: 3288
Vehicle:1998 Impreza 2.5RS Rally Blue Pearl |
My understanding is the 98 RS and 98-99 Legacy share identical engines. The 96-97 were also the same except they required premium fuel due to a different ecu.
That said ALL engine specs on my 98RS EJ25D are identical to what you list for your '96, compression, and timing are also identical. The only external differences I recall seeing on some 96-97's are the coilpack connectors and the intake tube. I suspect the difference is infact the ecu. edit: I'm no tec-geek, so I did consult my glovebox manual first to confirm... and it's the same. Last edited by Albert; 07-09-2003 at 04:24 PM. |
#4 |
Member#: 24043
Vehicle:2005 Legacy GT Sedan Silver |
My '97 Legacy GT doesn't require premium fuel, never has. I think the CR is something like 9.7:1-10.0:1.
I always wondered what the differences were. The reason for the power difference is probably using a less combustable fuel with slightly lower compression. Aside from that I am not sure what makes the necessity for the premium fuel. |
#5 |
Member#: 12535
NWIC
can you check in your owners manual to see the exact CR number? your 97 is DOHC right?
And if nothing mechanicaly changed it seems an ecu swap will give me more power and let me use lower octane fuel. Something else had to have changed. Maybe cams are different? |
#6 | |
Member#: 3288
Go fiigure...the '97 GT I tested during the Christmas break of '96 was one that required premium fuel ![]() |
#7 |
Member#: 12535
NWIC
any body have ecu pin outs for 96 and 97 legacys?
#8 |
Member#: 4423
Vehicle:'04 08 Tribeca, SVX Gold, Maroon |
In '97 Subaru reduced engine friction in many ways and also changed the FI map.
Changes: '96 Hydraulic valves, '97 adjustable valves '96 2mm offset wristpin, '97 .5mm offset '96 skirted pistons, '97 skirtless pistons (The combination of wristpin offset and skirtless piston produced the notorius "piston slap" noise) '97 increased compression and also became an interferance motor (9.7/1 iirc) Only '96 requires premium fuel |
#9 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
intersting .. that might very well make the 96 the best 2.5 for an aftermarket turbo setup . maf/ lower compression/ noninterfearance
ed do you think that you woudl be able to run a 96 with a 97 ecu and gain performance/ability to run less than preimum fuel? |
#10 |
Member#: 12535
NWIC
bump
#11 |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed |
97 2.5L motor
engine model EJ25D timing ????? Bore 3.92" Stroke 3.11" CR 9.7 to 1 From my owners manual ss |
| Thread Tools | |
| Display Modes | |
| Diffs between the USD EJ25 and the JDM EJ25 | BlackFighter | Factory 2.5L Turbo Powertrain | 2 | 05-06-2010 03:33 PM |
| WTB: Phase I Ej25 DOHC Heads and Intake | BhamRoadrunner | Private 'Wanted' Classifieds | 1 | 10-10-2006 09:56 AM |
| Differences between '04 FXT EJ25 and '06 FXT/WRX EJ25s? | Siper2 | Subaru Conversions | 26 | 01-09-2006 09:17 AM |
| What's the diff between DOHC EJ25 and SOHC | kickitjp | Normally Aspirated Powertrain | 18 | 04-07-2005 12:40 AM |
| EJ25 SOHC to DOHC and back again? | JoShYo | Normally Aspirated Powertrain | 16 | 11-14-2003 11:24 AM |
