Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-08-2003, 12:19 AM   #1
PowerGarage
Member#: 39069
04 STi
Default wheel spacer for STi
anyone recommend adding a spacer for the rear wheel?
PowerGarage is offline
Old 07-08-2003, 01:09 AM   #2
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Why?
ANZAC_1915 is offline
Old 07-08-2003, 01:41 AM   #3
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
If you did add spacers why would you just do it to the rear?
afpdl is offline
Old 07-08-2003, 02:10 AM   #4
Seraph
Member#: 12251
i'm guessing its for a hot-roddy look? or maybe he's got deep dish rims he'd like to use for the back
Seraph is offline
Old 07-08-2003, 02:13 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Again, Why?
Kostamojen is offline
Old 07-08-2003, 10:35 AM   #6
Seraph
Member#: 12251
Well without asking why over and over again, i think i've heard somewhere that wheel spacers for our cars with their wierd offsets can cause excess stress on the wheel bearings, which will cause premature failure.
Seraph is offline
Old 07-08-2003, 10:39 AM   #7
wrx what
Member#: 19697
2008 WRX STi
what wheels are you looking at
wrx what is offline
Old 07-08-2003, 11:34 AM   #8
Austin
Member#: 7089
spacers = more wheel fitment options... but not for the back...
Austin is offline
Old 07-08-2003, 04:37 PM   #9
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
to fit wider tires?
Old 07-08-2003, 05:02 PM   #10
Austin
Member#: 7089
Wider tires with more negative camber, and cheaper wheels which would otherwise smack the caliper.
Austin is offline
Old 07-08-2003, 06:27 PM   #11
metoo
Member#: 4764
2004 STi sold :(
forizzle
.....maybe to fit 17" SSR Competitions (not cheap). They require a 5mm spacer to fit over the front calipers. I've seen them personally fit on an STi this way.
metoo is offline
Old 07-08-2003, 06:47 PM   #12
boxerT
Member#: 16311
2004 STi
WR Blue
That was probably my STi with the SSR's at Subaru Challenge...? I am running 5mm spacers on the front and a 3mm on the rear. The rear does not need them, but that is what I have to almost even things out. I've tried the 3mm first on the front and the SSR's were just barely rubbing on the inside (close to the hub) of the caliper. With a 5mm spacer on the front, I have about 1/16" clearance. H&R makes quality spacers and 5mm ones are thin enough where the wheel still sits on the hub not just on the studs.
boxerT is offline
Wheel spacers for 04 STI BBS wheels 2006subaru Tire & Wheel 16 06-15-2009 11:39 AM
wheel spacer for wrx's spare tire to fit sti front wheel? stiboss Tire & Wheel 3 04-10-2008 11:32 AM
Ebay knockoff wheel spacer for my spare wheel? broom_dude Tire & Wheel 1 04-22-2005 02:44 AM
wheel spacers for wrx wagon w/sti brembos Benjamin Tang Tire & Wheel 11 02-23-2004 11:50 AM
Using wheel spacer for STI Nzo Tire & Wheel 14 11-18-2003 07:33 PM
