Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 07-08-2003, 01:26 PM   #1
shipjumper
Member#: 6307
what I has no car...
am carless
Default clunk clunk
ok heres my issue. I have a 1991 legacy turbo. I have put in a set of KYB AGX and a 23mm front and rear adj sway bar.
heres the problem, when going over bumps or loading and unloading the front two corners I get a clunk, or a pop, a popping clunk, like something is hitting something or jumping threads.
has anyone else encountered this? is this a common thing for AGX owners?
let me know! its annoying!
shipjumper is offline   Reply With Quote
Old 07-08-2003, 02:47 PM   #2
jkyes
Member#: 707
99 Legacy GT
Quick silver
front or rear?
there was a recent post about some noise problems some peole where having in the rear of there car. i just found out my brullen muffler was rubbing up against the body of the car, and the noise i was having up front was a bad ball joint, so that is now replaced.
here is the link to another noisy car problem.
http://forums.nasioc.com/forums/show...hreadid=368718
jkyes is offline   Reply With Quote
Old 07-08-2003, 03:19 PM   #3
shipjumper
Member#: 6307
am carless
its only front end and when im going over a bump, sidewalk rise, pothole, hard corner load on one side, etc
Old 07-08-2003, 04:01 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Two of the most common reasons
Loose strut top bolt
Loose (or bent) sway bar mount
Where did you get a front 23mm adjustable? I have NEVER seen one.
Old 07-08-2003, 06:07 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
Did you replace the struts yourself? If so, did you get the springs re-installed the right way. When I did mine (first timer), I put them back together the wrong way, kinda twisted around. The top and bottom caps have a certain side that needs to face out. Anyway, mine was making that popping, clunking sound when the front suspension was working. Turns out the passenger side spring was rubbing against the inside of the fenderwell, making the noise. Took it apart again, paid attention, realized the error of my ways, and learned something. (Hopefully I'll remember it!)
Anyway, hopefully that's not an offensive suggestion. It's just something I've done in the past.
Rich
richeich is offline   Reply With Quote
Clunk Clunk Clunk Ryanr1490 Transmission (AT/MT) & Driveline 5 12-17-2007 01:59 PM
Clunk Clunk Clunk (suspension prob?) SplatterThrash Brakes, Steering & Suspension 16 07-08-2006 02:38 PM
Clunk Clunk Clunk Clunk subajay New England Impreza Club Forum -- NESIC 6 11-19-2005 09:39 PM
clunk clunk in the front......clunk in the back Silver on Blacks Brakes, Steering & Suspension 9 11-02-2005 06:35 AM
Clunk..Clunk...Clunk Scooby South Brakes, Steering & Suspension 7 03-01-2001 03:15 PM
