Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 07-08-2003, 03:15 PM   #1
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Default Knocklink installation
Has anyone successfully installed a KnockLink unit on their STi? I just want to know, before I order one. Thanks in advance!
wolverine is offline
Old 07-08-2003, 03:28 PM   #2
PunksWRX
Member#: 5504
2004 Impreza WRX STi
I moved my Knock-Link from my 02 WRX to my 04 STi and used the identical installation procedure. I mounted my Bosch sensor to the block right under the intercooler on the drivers side. The sensor is grounded at the body ground point on the transmission hump. I have my Knock-Link display unit mounted at the ashtray location and used the cigarette lighter circuit for my power/ground for the dispaly unit. It works fine in the STi.
Punk
PunksWRX is offline
Old 07-08-2003, 03:43 PM   #3
wolverine
Member#: 36571
2004 WRX STi
Black & gold
PunksWRX,
Did you have to use a longer bolt on the manifold to hold the sensor in place? If so, is it hard to find the new bolt? Thanks.
Old 07-08-2003, 06:00 PM   #4
PunksWRX
Member#: 5504
Yes you do need a longer bolt. The bosch sensor is probably 3/8" to 1/2" thick. On the stock STI there is a metal bracket that holds a metal vacuum line assembly in the hole you need to use (that hole is empty on the WRX). Just remove that bolt and take it to NAPA and get the same size bolt with the extra length and you are in business. Just leave the metal bracket sandwiched between the block and the sensor.
I spoke with one guy that mounted his Bosch sensor on the intake manifold bolt/stud which would be easier since you don't have to remove the intercooler but I would be a little more concerned about the sensitivity since the knock frequencies would then have to transmit through the bolt/manifold gaskets/intake manifold. I figured that might reduce sensitivity. Probably better to have it mounted right on the block.
Punk
PunksWRX is offline
Old 07-09-2003, 12:34 AM   #5
wolverine
Member#: 36571
2004 WRX STi
Black & gold
I would mount it on the block. Thanks for your help, PunksWRX!
Old 07-09-2003, 01:33 AM   #6
silver ghost
Member#: 36970
2004 WRX STi
Default Re: Knocklink installation
sorrie this is a dumb noob question but what does the KnockLink unit do? does it alert and prevent engine knock?
thanks, Ghost
silver ghost is offline
Old 07-09-2003, 09:27 AM   #7
davidm_sh
Member#: 5994
Java Black
Hey Paul-
Have you seen any signs of detonation on the knocklink up here at 6000ft? What gas do you run in your STi? Just curious.
Thanks
davidm_sh is offline
Old 07-09-2003, 09:34 AM   #8
inchoate
Member#: 5470
2004 STi
blueish
silver ghost:
the knocklink just shows you if you're experiencing knock. it does nothing to prevent the problem. but hey, knowing you have a problem is the first step to fixing it, right?
inchoate is offline
Old 07-09-2003, 11:12 AM   #9
wolverine
Member#: 36571
2004 WRX STi
Black & gold
Default Re: Re: Knocklink installation
thanks, Ghost
Here ya go... http://link-electro.co.nz/knocklink.html
I'm planning to replace the yellow and red LED's with the message "Feed me more toluene now!"
Knocklink install help Chigliakus Texas Impreza Club Forum -- TXIC 5 02-21-2005 06:24 PM
Knocklink install help Chigliakus Electrical & Lighting 1 02-21-2005 05:03 PM
KnockLink install tomorrow....who wants to help? Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 7 09-23-2002 11:08 PM
Knocklink Install w/Bosch sensor JayGold Factory 2.0L Turbo Powertrain 2 09-23-2002 11:36 AM
KnockLink install mpj_becks Factory 2.0L Turbo Powertrain 7 10-19-2001 11:07 PM
Message Board Statistics All times are GMT -4. The time now is 12:02 AM.
