Old 07-08-2003, 09:54 PM   #1
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Default Got my link and RC injectors today!Now for the questions..
First off it plugs in place of the ecm correct?Then I bolt it down with the supplied brackets right?Are there any installation instructions online?
Also for the RC injectors which wire goes where for the inector pigtail?
Ben,
Old 07-09-2003, 09:26 AM   #2
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
ABOUT DARN time! Come on now. I had my second kit Trunkmounted for almost a year already, and you just got the Link x10
J/k
Yes it will plug into your harness, given you got the plug and play harness with the link. You need to run a vaccum line for the onboard MAP sensor trough the firewall to the ECU location.
Make sure there is NO RESTRICTOR IN THE VACCUM line. (like the vaccum gauge line on OEM performance gauge cluster)
The link ECU is a bit taller than the OEM ecu so cover it up with something do it doesnt get scrached up by the floor plate after you reinstall it.
Cheers
Edit: corrected sensor
Marcin is offline   Reply With Quote
Old 07-09-2003, 10:07 AM   #3
rhdude
Member#: 6637
2009 Acura MDX Sport
Originally posted by Marcin
Yes it will plug into your harness, given you got the plug and play harness with the link. You need to run a vaccum line for the onboard MAF sensor trough the firewall to the ECU location.
MAP sensor
rhdude is offline   Reply With Quote
Old 07-09-2003, 10:29 AM   #4
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Also. Swap your O2 sensors, so the rear o2 sensor is on your downpipe, get rid of your front o2 sensor (or just use it to plug the hole after the cat)
LINK reads better there.
Wedge is offline   Reply With Quote
Old 07-09-2003, 10:19 PM   #5
kaos200
Member#: 2692
wait the Link PNP uses the rear 02???
kaos200 is offline   Reply With Quote
Old 07-09-2003, 11:23 PM   #6
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
http://www.wrxhackers.com/modules.ph...iewtopic&t=329
That's from Bill (skywalker) @ I-SpeedUSA
Old 07-10-2003, 08:06 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
As of right now the car has no a/f or o2 sensors.I plan on running the rear sensor (wideband IIRC) where abouts is a good place to put it?
Also which wire goes where for the injector pigtails?
Ben,
Thanks for all the help.
Wait wait wait, WTH are these? I go on vacation for 2 days and we get new smilies?? SWEET!!
Old 07-14-2003, 09:04 AM   #8
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
IIRC, the ordering positioning of the wires doesn't matter. But here's what I did. Left goes to left, right goes to right when holding the injectors side by side. Worked fine for me with the Link and the RC440's I had.
Yes, switch the O2 sensors. The best place to put the sensor IMO is right after the turbo in the downpipe.
wcbjr is offline   Reply With Quote
Got my protune at GRD, just in time for the shootout. Amplified2000 Mid West Subaru Owners Club Forum -- MWSOC 4 09-25-2007 07:12 PM
For Sale!!!need To Get Rid Of! T04 Hybrid Turbo,2.0 Block,and Rc Injectors 800 CrAzY5o0wHp Tri-State Area Forum 1 05-20-2005 09:25 PM
I got my review and a raise today! Brad Pittiful Off-Topic 30 03-17-2005 07:57 PM
Should I sell my car and buy a Rex? That is the question. jpwrx02 Newbies & FAQs 31 02-26-2004 02:37 PM
Got my Vishnu re-mapped chip today ... Question? makofoto Engine Management & Tuning 7 05-05-2003 02:46 AM
